6
EDIT: I don't think I'm using the term "negative feedback" correctly. What I meant is, how does the feedback that makes the closed loop gain equal to 1 work?
I'm trying to understand the very basics of oscillators and I came across this article (if the page is down, go here (page 3)). Here is the circuit:
As I understand it, there is a positive feedback through C2 because when, for example, the voltage across L1 rises then the voltage across R3 must fall. Since that increases the base-emitter voltage then the collector current will increase accordingly (alternatively, the collector-emitter voltage drops and the voltage across the tank must increase).
Now I'm not so sure about the negative feedback, which apparently (see the link above) is because the dc build up in R3 (or C2) makes the amplifier go from operating in class A to class C.
For that purpose I ran some simulations in TINA. First I added a resistor in series with the tank capacitor so I could see the feedback response more clearly. Then I took out the resistor to confirm the circuit was working as an oscillator. The values used were taken from the page following the article linked above. Here is the circuit and the results INCLUDING the "lossy" resistor (labeled R4):
As you can see the oscillations in Re tend to build up a DC level with increasing amplitude. This seems to suggest that the transistor is operating in the cutoff region when the wave goes negative, and operating as usual (as in class A) during the positive part. Over time this will charge C2 and provide the automatic sliding towards class C described in the article (this is what I incorrectly called "negative feedback"):
I would like someone to confirm if this is what's happening or if I'm wrong.
Here is what you get when you short R4 (the added resistor):
So the circuit is indeed working as an oscillator.
@Ant, here some my observations on this classic oscillator that can help.
Really, R3 introduces negative feedback (emitter degeneration) that stabilizes the operationg point. But it plays another important role - as an element (the lower leg) of the positive feedback network (the voltage divider C2-R3). Figuratively speaking, R3 makes the emitter "soft", "movable" by the collector through C2. So R3 is inserted between the emitter and ground to implement the positive feedback as well.
Another interesting phenomenon in this circuit is that (I suppose:) the collector voltage Vc (compared to ground) should sinusoidally rise above Vcc and drop below it; so it is interesting to see how it exceeds the power supply.
Finally, you can see that looking from the side of the feedback, this is a common-base emitter stage (since the base voltage is fixed by C1); this is in regards to the AC changes. But looking from the side of the DC input circuit (the voltage divider R1-R2 and th capacitor C1), this is a common-emitter stage with degeneration.
My final conclusion is that the role of the negative feedback is not so important here but the role of the positive feedback is cruicial. So I'm a little puzzled by your question.
Incidentally, as a brief regression, your question reminded me of my childhood (the late 60as), when I was doing exactly such circuits of radio transmitters to command various models (and also to disturb the TVs of the neighbors:)
@hkBattousai, in contrast to your formal explanation, I will explain here the circuit operation in an intuitive manner.
The basic idea of an LC oscillator is simple - the oscillations are produced by an LC tank (you can see how in this Wikibooks story), and the active electronic circuit (the transistor amplifier here) only sustains the oscillations by adding the additional energy needed to compensate the losses inside the tank. Let's see how it is implemented here...
Imagine C3 is initially charged with such a polarity so its lower plate (connected to the collector) is negative. When C3 discharges through the inductor, the voltage across the tank decreases, and the collector voltage Vc (in regards to ground) increases. The so important capacitor C2 (as LvW said) transfers (almost without change) this voltage "movement" up to the emitter. Figuratively speaking, the LC tank "pulls up" the emitter through C2 (acting as a sort of a "shock absorber") thus cutting off the transistor. So, in this phase, the LC tank operates unaffected by the transistor...
The voltage across the LC tank and, accordingly the collector voltage, reach their maximum above Vcc, and after that begin decreasing. Now the C2 "shock absorber" begins "pulling down" the emitter... and, at some lower point, the transistor begins turning on... its Vc decreases... thus "helping" the LC tank to "pull down" the emitter... and so on...
More professionally speaking:), the transistor adds additional charging current in parallel to the inductor current to charge more the capacitor (it is interesting to draw the charging current loops).
Now about the @Ant's question "why the DC level of C2 builds up" that actually means to explain what happens when this LC oscillator is powered up (the transition in the beginning). For this purpose, it would be extremely useful to remember how the ordinary swing for children (the LC tank here) gradually increases its amplitude in the beginning. Also, imagine you push and pull such a swing through a shock absorber (C2).
When you turn on the power supply, the capacitors C3 and C2 are initially discharged (zero voltage across them)... so the emitter is "pulled" up to Vcc. The base-emitter junction is backward biased and the transistor is cut-off. The LC tank begins freely to swing... and the collector voltage amplitude gradually increases. C2 (the "shock absorber":) gradually charges through the LC tank and the emitter resistor R3... the voltage VC2 across it gradually increases... and the emitter voltage gradually drops "moving away" from the collector voltage...
At some point, when it is at its minimum, the swinging emitter voltage reaches the constant base voltage... and periodically goes down below it... at these moments, the transistor begins turning-on thus sustaining the oscillations in the LC tank...
In our child swing analogy, this means the shock absorber is already extended, and we have moved away from the child:)
  • \$\begingroup\$ Thanks, but could you expand on why C2 (the C2 of the first picture) DC level is changing? is it because the the transistor is being cut off when the amplitude is high enough (but not high enough to saturate)? \$\endgroup\$
    – 4nt
    Jan 29, 2015 at 20:27
  • \$\begingroup\$ C2 slightly changes its charge (discharges a bit when Vc decreases, and charges a bit when Vc increases), since some current flows through it. The larger the C2 capacity (the higher the frequency) is, the less the voltage across it will change. Think of it as of a kind of a "shock absorber" transferring the collector "movement" to the emitter:) \$\endgroup\$ Jan 29, 2015 at 23:13
  • \$\begingroup\$ Hmm... really C2 changes slowly and sinusoidally (with a low frequency) its DC level... Maybe this is the Armstrong's super-regenerative effect? I don't know... \$\endgroup\$ Jan 29, 2015 at 23:22
  • \$\begingroup\$ Thanks. Have you read the article, especially the part where it mentions C2? it says that the DC level builds up with increasing amplitude, so the amplifier doesn't amplify infinitely, but it doesn't mention why the DC level builds up, that's my doubt. \$\endgroup\$
    – 4nt
    Jan 30, 2015 at 2:43
    \$\begingroup\$ @Ant, I have not read it... but I have no a great desire to read it because I guess what is written there. Instead, I will try to explain in a fully intuitive (human:) manner how this LC oscillator starts at power up... and even what is the super-regenerative idea proposed by Armstrong a century ago... BTW here is much more interesting than in Wikipedia, Wikibooks and ResearchGate where I have been contributing as well... \$\endgroup\$ Jan 30, 2015 at 6:34
R1 and R2 constitute a voltage divider to DC bias the BJT. Prabably R1=R2, so that the oscillator will work around the middle point of the Vcc and have the maximum swing ability on the both sides.
C1 is for keeping this divided voltage more constant. As the base of the BJT drains current, this voltage will drop down. In order to keep the bias DC voltage fixed, a relatively large C1 filtering capacitor is needed.
This type of BJT amplifiers have voltage gain of
$$ \text{Gain} \overset\sim= \dfrac{\text{Collector Impedance}}{\text{Emitter Impedance}}. $$
Parallel connected L-C elements make infinite impedance at a specific frequency of \$\dfrac{1}{\sqrt{LC}}\$. In other words, at a certain frequency, the collector impedance becomes maximum. Thus the gain becomes infinite. This frequency is the frequency of the oscillator.
But we don't want the L-C filter to have infinite impedance, because it means infinite output impedance; we can't have any output reading. Maybe the C2 is for preventing this. I don't know.
C4 is the output by-pass capacitor. It is for making the output AC only.
C5 is for keeping the Vcc at a fixed level. If the frequency of the oscillator is too high and the path to the source of Vcc is far away, the trace inductance will make create ripples on Vcc near the oscillator. C5 is for filtering these ripples out.
    \$\begingroup\$ Some comments: C1 keeps the base at signal ground - hence, the whole circuit works in common-base configuration. And the capacitor does not "prevent" something - in contrary, it is the most important part because it establishes positive feedback (necessary for each oscillator). The feedback is positive because for common base stages there is no phase shift between emitter and collector. \$\endgroup\$
    – LvW
    Jan 28, 2015 at 13:47
  • \$\begingroup\$ @LvW Thank you. Can you please tell me the function of C2 as well? \$\endgroup\$ Jan 28, 2015 at 14:51
    \$\begingroup\$ @hkBattousai, I think that LvW talks about the capacitor C2, not about C1, when saying "And the capacitor does not 'prevent' something - in contrary, it is the most important part because it establishes positive feedback (necessary for each oscillator)". BTW your explanation is very formal and it provokes me to explain the circuit operation in an intuitive way... \$\endgroup\$ Jan 28, 2015 at 15:56
    \$\begingroup\$ Thank you for clarification. And - of course - while speaking about feedback I was referring to C2. As mentioned, C1 establishes the common base function and C2 is feeding back to the emitter a part of the output voltage. For common base stages, the gain from the emitter node to the collector has no phase inversion and, therefore, C2 provides POSITIVE feedback. \$\endgroup\$
    – LvW
    Jan 28, 2015 at 17:43
