I am working on a design that has at least a dozen FPGA's. In the past I have had an FPGA get damaged by a faulty voltage regulator and short out the supply input to ground.Chasing down which FPGA was defective was challenging. I want to have the several voltages be interrupted to each FPGA so I can debug by removing components in series with the power lines to each FPGA. Has anyone done this before? How can it be done?
    \$\begingroup\$ Sounds like a good idea, but what is your question? \$\endgroup\$
    – Justin
    Jan 28, 2015 at 20:30
One possible technique is to take advantage of a commercial test instrument. Specifically, I'm referring to something called a "Leak Seeker" from Electronic Design Specialists (EDS). If you do your PCB layout such that the power pin(s) for each FPGA is available on a via as close as possible to the chip, finding shorted chips is relatively easy. If the FPGA chips are fed from a power plane in the PCB, ensure that the plane feeds this via from a short trace and that the via is what feeds the power pins for the chip.
The Leak Seeker is a device that is used for finding shorted components on PCBs. The original version is a primarily analog design that injects a small test current into a node on the board, then uses a sensitive voltage-controlled oscillator to guide the user to move the test probe along the trace searching for the short. I have one and it works very well.
The unit has been recently updated and I don't have any experience with the new version. However, the original version was capable of finding shorted chips even if those chips were being fed from a dedicated power plane in the PCB. Leek Seeker page
The reason for having a dedicated via for each chip is that gives you an easily measured point when tracking down damaged chips. The real advantage to this technique is that no extra components are required.
You can put down a resistor footprint and populate it with a 0 ohm resistor, this makes an easy to disconnect connection. Since you're going to be putting power through them anyway, you could put a ferrite choke there instead of the 0 ohm resistor, that way you get some power filtering too.
  • \$\begingroup\$ Got to be a little bit careful with the inductor thing, but I often find myself placing footprints for such things because it is a useful approach. However the isolation part needs to be before the (Generally extensive) HF decoupling so telling the difference between badly fitted BGA and cracked decoupling cap can still be a pain in the arse. \$\endgroup\$
    – Dan Mills
    Feb 3, 2019 at 15:17
