I am building a digital alarm clock, and I need a chip holder for the LM8560 chip. I tried a sop 30 to dip 30 holder. The chip fits on width but not length. The chip is to long and even if I used sop 40 to dip 40 chip holder not all of the pins on the chip would align with the holes in the socket. I have tried making a chip holder by drilling holes in a piece of MDF, sitting the chip in those holes and soldering wire to the chip pins. However in the process I believe I damaged the chip and the circuit will not work properly. Could someone please recommend me a chip holder that would work, or a method of building one that would not require soldering anything to the chip pins? Or even a company who makes custom chip holders?
  • \$\begingroup\$ The only datasheet I could find for LM8560 show it being a sdip28 chip which means you need a sdip to dip adapter (sdip is a skinny dip which is thinner than dip, sop is a surface mount pkg which is thinner and shorter than dip). can find a 28 pin one here - epboard.com/eproducts/… \$\endgroup\$
    – I. Wolfe
    Jan 29, 2015 at 17:40
  • \$\begingroup\$ Picture of your ic on the chip holder please? \$\endgroup\$
    – Passerby
    Jan 29, 2015 at 17:57
The datasheet I found show the LM8560 being a SDIP chip and not SOP. This means you need a SDIP to DIP adapter (sdip is a skinny dip which is thinner than dip, sop is a surface mount pkg which is thinner and shorter than dip).
I have used these guys before: http://www.epboard.com/eproducts/ezadapter.htm#Shrink%20DIP%20%28SDIP%29%20to%20DIP%20Adapter
They have a SDIP to DIP 28 pin adapter if that's what you require. They also do custom adapters where you can give them the specs and they make the adapter for you.
  • \$\begingroup\$ Thanks that link was really useful I might end up using a chip holder from there \$\endgroup\$ Jan 29, 2015 at 19:33
Try using swiss machine pin headers.
Machine Pin Headers
If the pitch doesn't match the pitch on your chip, you could look at making a custom little PCB socket to convert to a more useful pitch too.
  • \$\begingroup\$ That's interesting the chip holder I purchased used those with a custom PCB setup, so I can recycle the machine pin headers off that \$\endgroup\$ Jan 29, 2015 at 19:32
According to this almost-10-year-old post from a usually reliable source, production SDIP sockets (1.778mm pitch) are (or were) available from Assman and test sockets from Yamaichi.
Mouser currently has 28-pin ZIF 1.778mm pitch sockets from 3M in stock 228-1290-00-0602J and, as usual, they're quite expensive.
Also, for an intermediate cost (machined pin rather than stamped), currently, Mill-Max and Precidip have 1.778mm pitch 28-pin sockets for about $5 each in singles. For example, this one P/N 117-93-628-41-005000 from Mill-Max.
