I'm interested in having two or more cameras precisely synchronized for machine vision purposes. All the global shutter cameras I've seen basically have two modes: free-running, with a maximum frame rate of X FPS, and triggered, with a maximum triggering rate of X/2 FPS.
This is a frustrating limitation. Shouldn't it be possible keep two free running cameras very closely synchronized using an external feedback controller? Each camera could pulse a pin letting you know when it's capturing a frame, and as long as there was a scheme for introducing a very slight delay into one or the other of them, you could nudge them together, similar to how the NTP daemon nudges a computer's clock.
Does anything like this exist? Is there a camera sensor or module out there which has the necessary rate control capability necessary for it?
Thanks for any thoughts or input.
