I am using MPLABX v2.25 and XC32 compiler v1.33 on a Mac.
Maybe I am not fluent with the use of the preprocessor, but the macro expansion window in MPLABX seems to produce rather unexpected results.
Example-1:
#define PIBO TEST
void ftest(void)
#if (PIBO == TEST)
  printf("Hello");
#endif
Expected Result: printf() should appear in the macro expansion window
Result: printf() does appear in the macro expansion window
So far so good.
Example-2:
#define PIBO FOOTEST
void ftest(void)
#if (PIBO == TEST)
    printf("Hello");
#endif
Expected Result: printf() should NOT appear in the macro expansion window
Example-3:
void ftest(void)
#if (0)
    printf("Hello");
#endif
Expected Result: printf() should not appear in the macro expansion window
Result: printf() does not appear in the macro expansion window
Is the MPLAB X macro expansion window showing faults or is it my code or understanding of how this is supposed to work?
    \$\begingroup\$ Not sure how the pre-processor would process it exactly but because == can't be used for string comparison in C I wouldn't expect it to work. The more usual thing would be to #define FOOTEST 1 and #define TEST 2 etc so the comparison is a numeric one. \$\endgroup\$
    – PeterJ
    Commented Feb 6, 2015 at 7:27
  • \$\begingroup\$ In C, undefined symbols in the preprocessor evaluate as 0. Therefore, your first two examples all evaluate as 0 == 0 which is true. if you #define x 1 and #define y 2 then (x == y) evaluates as (1 == 2) which is false. \$\endgroup\$
    – DoxyLover
    Commented Feb 6, 2015 at 7:28
  • \$\begingroup\$ @DoxyLover, I wasn't sure how it handled undefined symbols, you might as well post that as an answer. \$\endgroup\$
    – PeterJ
    Commented Feb 6, 2015 at 7:31
If you
#define x 1
then
#define y 2
