I'm trying to work on a prototype wearable indoor and I am really confused as to how I am going to transfer data fetched from the GPS device to the server. Is GSM module
the best option or should I go for WiFi
? How can this be achieved and what are my best options?
1 Answer
If your final product is designed to be worn outside you have to go down the GSM path as it work in a wider range. If it is indoors only Wi-Fi is more appropriate.
The reason is cost. GSM covers a wider range, but it requires a more expensive module, and you also have recurring costs from the cellular carrier and running a publicly accessible server (since you need at least either a static IP address or a domain name, and either of them cost money.) Wi-Fi, however, covers only inside and immediate around the building the access point is set up, but requires only a cheaper module, and since it is, after all, LAN, so there is no recurring cost other than electricity bill (which you also have to pay if you go down the GSM path anyway)
\$\begingroup\$ Can you offer more on why? My suggestion to the OP would have been more on mobility required and who controls the WiFi before answering. I don't see how indoors/outdoors by itself determines WiFi. \$\endgroup\$– kennyFeb 6, 2015 at 11:17
\$\begingroup\$ @kenny Cost. GSM can have long standing recurring cost from a carrier (and a higher initial cost too) but Wi-Fi have only a lower one-time cost. Also running a server that is publicly accessible also cost more as you need at least either a fixed IP address or a domain name, and both cost money. \$\endgroup\$ Feb 6, 2015 at 11:21
\$\begingroup\$ that's a good point. It's a lot more than just inside/outside. \$\endgroup\$– kennyFeb 6, 2015 at 11:28
\$\begingroup\$ @kenny Since the range of Wi-Fi is usually limited to indoors and immediate around a building you might as well categorize your use case as indoors or outdoors. \$\endgroup\$ Feb 6, 2015 at 11:39
2\$\begingroup\$ If it's indoors, the GPS isn't going to be much good in the first place. \$\endgroup\$ Feb 6, 2015 at 13:11
