I'm trying to figure out how I'm supposed to get traces to the four internal data pins of the Wolfson WM7230 Digital Microphone part.
WM7230 Bottom Port Digital Mic
It's got a ground ring that is supposed to have a tight solder seal. You can see from the datasheet recommended PCB pattern, that the four internal pads are completely surrounded by the copper ground ring.
WM7230 Recommended PCB Land Patterns
I thought it was bad news to put vias in the pads themselves. This thing is a pretty small part; is the intention that I put via's immediately next to the pads?
Tried to find some example layouts with Google, but no luck.
Thoughts?
Ok, got some advice from the twitterverse:
https://twitter.com/JulianVeisdal/status/564144465225715712
"For parts with perimeter ground ring (E.g.WM7211, WM7210, WM7230), it is not critical to
