When I try interactive routing, the traces don't show up until after I leave the interactive routing state. I've tried resetting desktop layouts, and showing all connections, but nothing I've seen works.
I'm running altium 13.3 in windows 7 in virtualbox (base os is Ubuntu 14.04)
  • \$\begingroup\$ Have you tried running Altium in virtual box before? It might be the virtualbox which makes it not work correct. \$\endgroup\$
    – Triak
    Commented Feb 9, 2015 at 21:39
  • \$\begingroup\$ @Triak I haven't run altium in virtualbox before. it's possible the virtualization is affecting it, but I'd like to know why, especially because I feel like once the cause is know, there's a good chance it can be fixed. As I'm looking into things, it looks like directx isn't being rendered correctly, so I'm going to pursue that line. \$\endgroup\$ Commented Feb 10, 2015 at 18:42
  • \$\begingroup\$ Maybe try wine? \$\endgroup\$
    – Triak
    Commented Feb 10, 2015 at 19:09
Please, Check this preferences.
  • \$\begingroup\$ So alpha blending is "buggy / not supported" in Virtual Box? \$\endgroup\$
    – Rev
    Commented Nov 9, 2015 at 9:25
In my case (using Altium 16 on VMware Workstation) Kübra answer won't work for me, but in the same page I found another solution.
Go to Tools>Preferences>Display and then disable Apply Mask During Interactive Editing as shown bellow.
  • EDIT: There is an option in View>Decrease Mask Level, with "[" and "]" shortcut button. After using these commands I can adjust my mask level which is why I see all darks in interactive routing mode.
