Every explanation I've seen so far about voltage dividers, only consider the two main resistors (that do the "dividing"), and pretty much ignore what happens after Vout
The circuits in the explanations look more of less like this:
In this example the voltage at Vout
should be 2.5V.
This really gives the impression, that whatever goes on for the rest of the circuit, Vout
is at 2.5V.
But what happens in practice, if I get something connected to Vout
? E.g, I connect some components, and their equivalent resistance is 100Ω:
Since R2 and R4 are in parallel, an equivalent resistor would be of 50Ω. Now, if that's correct, then the voltage divider really operates between a 100Ω and a 50Ω resistor. I.e. the voltage at Vout
would be 1.67V and not 2.5V, as I originally wanted it to be.
Is this really how it works?
How should one design the part that connect to Vout
to avoid messing up the divider?
