Neon lamps have higher breakdown voltage than its operating voltage. When brokendown, it acts like a zener at its operating voltage.
\$\begingroup\$ The only one that springs to mind is a Neon lamp. \$\endgroup\$ – Majenko Feb 11 '15 at 10:31
\$\begingroup\$ Gas lasers behave the same way, if I remember correctly, but well they are just improved neon lamps. \$\endgroup\$ – Arsenal Feb 11 '15 at 10:57
\$\begingroup\$ A thiristor is a typical current controlled negative resistance device (S shaped lambda diode) \$\endgroup\$ – GR Tech Feb 11 '15 at 16:44
\$\begingroup\$ encyclopedia2.thefreedictionary.com/… , en.wikibooks.org/wiki/Circuit_Idea/Negative_Resistance , en.wikibooks.org/wiki/Circuit_Idea/… . Gas ionization would have the current "S" characteristics, Arc welding, Lightning, Florescent lights, Spark gap, etc. Gas discharge limits frequency response. Emulating "S" curve with a circuit can overcome that. \$\endgroup\$ – Optionparty Feb 11 '15 at 17:43
Add a comment
How about a diac or sidac diode? They have somewhat similar curves but in different ranges.
I suppose you might consider a unijunction transistor.
