I'm trying to implement a 3-bit counter using basic gates (AND, OR, XOR, NOT etc..) around 3 D-type flip-flops. The input is an increment signal that when set to 1 will allow the counter to increment by 1. There are 3 outputs count(0), count(1) and count(2) where count(0) is the lsb.
But I'm not sure how can I handle the set in D-type flip-flops. I have illustrate as follows but you can find there is set port in DFF. So How can I make set in verilog? I'm not sure is this meaning reset? if yes, what if set is 1, is meaning negative reset? or positive reset?
How do I modify as above rule (the input is an increment signal that when set to 1 will allow the counter to increment by 1)? Am I interpreting it right or wrong?
UPDATE:
Is this the same thing?
always @ (posedge clk or negedge reset )
if(set)
begin
Q<=1'b1;
end
UPDATE:
wire q0;
wire q1;
wire q1_i = (q0 ^ q1);
wire q2;
wire q2_i = (q2 ^ (q0 & q1));
dar u_dar1 ( ~q0 , clk , reset_n, q0);
dar u_dar2 ( q1_i , clk , reset_n, q1);
dar u_dar3 ( q2_i , clk , reset_n, q2);
wire [2:0] rere = {q2,q1,q0};
module dar (
data , // Data Input
clk , // Clock Input
reset , // Reset input
q // Q output
input data, clk, reset ;
output q;
reg q;
always @ ( posedge clk or negedge reset)
if (~reset) begin
q <= 1'b0;
end else begin
q <= data;
end
endmodule
