I'm trying to power an ATtiny44 (1.8 V/5.5 V) from the balance port of an RC 2s/3s lithium polymer battery.
The circuit will use very little current, sleeping 29 secs/1 µA?, wake 1 secs/10 mA. The circuit is a Lost Model Alarm, so after 10 minutes, it will blink/beep, and then sleep for 30 secs, then repeat, ideally, for as long as possible (> 3.3 V/cell).
In terms of longest operation (not dropping below 3.3 V on each cell), is it better to power the circuit from an LDO regulator using all available cells (3.3 V/8.4 V/12.6 V), or directly from one cell, and no LDO regulator at all?
I realize that powering from one cell will make the lithium polymer battery unbalanced, but not damage it if the cell remains above 3.3 V.
I guess it will depend on the efficiency of the LDO regulator, but I'm not sure how to work the numbers out. To me, using all cells means the longest runtime, but I'm not sure about dropping from 12 V to 1.8 V/5 V and the loss.
References:
    \$\begingroup\$ A BEC would be an efficient solution as it uses a switching regulator and have connectors for RC lipos, see: en.m.wikipedia.org/wiki/Battery_eliminator_circuit Depends if you want efficency or easy on the pocket. \$\endgroup\$
    – RSM
    Commented Feb 11, 2015 at 17:38
  • \$\begingroup\$ Not all BEC's are switching. Most are, but some are still linear. Either way, +1 for the idea. \$\endgroup\$
    – AaronD
    Commented Feb 11, 2015 at 18:01
  • \$\begingroup\$ thx for suggestion, but I don't want to add a bec, or use the existing one on the model, just the balance port on the battery + LDO if necessary. \$\endgroup\$
    – protoc0l
    Commented Feb 11, 2015 at 20:01
If you use a linear regulator the number of cells makes no difference to run time, since the same current is being drawn anyway. Whether that current is drawn from 1 or 3 cells doesn't matter, as the pack is deemed fully discharged when any cell reaches minimum voltage.
However if you tap into a single cell then it will be discharged more than the others, so the battery will have to be balanced on recharge. The worst case scenario is if your ATTiny circuit is the only load, as then the other 2 cells in the pack will remain fully charged and cannot accept any current on recharge.
Whether your charger can correct the imbalance depends on how it works and what other current is drawn from the pack. Some charge each cell independently, so it doesn't matter how unbalanced the pack is. Others charge the whole pack in series and bypass current around any cells with higher voltage, so to avoid overcharging the higher voltage cells the charge rate must not be be higher than the balancing current.
If you have another circuit connected to the whole pack which draws a lot more than 0.33mA on average then the battery will be discharged long before it has time to go badly out of balance. In this case you don't have to worry about regulator efficiency, because its power drain is a small proportion of the total. Therefore it would be best to power the regulator from all cells, since that would avoid unbalancing the pack. With efficiency not being important and 7.4V or 11.1V available, you don't need an LDO regulator (a standard 78Lxx type would work fine).
If reducing that 0.33mA draw would significantly improve overall efficiency then you are risking serous imbalance and probably should avoid tapping into one cell. In that case a switching regulator could improve efficiency. To do so it would have need to have a very low quiescent current draw (much less then 0.33mA) and high efficiency at 10mA.
  • \$\begingroup\$ thx for detailed reply! My rc charger(and most computer-controlled hobby ones) can handle the imbalance, but it does seem to be the consensus to use all available cells + LDO of some sort. This is for a Lost Model Alarm, so after 10 mins, it will blink/beep, and then sleep for 30 secs, then repeat, ideally, for as long as possible (> 3.3v/cell). \$\endgroup\$
    – protoc0l
    Commented Feb 11, 2015 at 20:11
  • \$\begingroup\$ PS: the LDO claims quiescent current: 4ua (typ.). I think I could get down to 1ua (Attiny sleep) by not using the LDO at all and just one cell from lipo, but seems like its not recommended. \$\endgroup\$
    – protoc0l
    Commented Feb 11, 2015 at 20:18
Rather than risking to unbalance the battery; a Step-Down Buck Converter would help you achieve the desired voltage at low loss.
  • \$\begingroup\$ I agree. I would not pull power from one battery in a series stack. You can use a switcher or an LDO. An LDO is fine for such a small load. It may be a challenge to find an LDO that can withstand 12.6V input, however. \$\endgroup\$
    – user57037
    Commented Feb 11, 2015 at 19:34
  • \$\begingroup\$ thx for comments, the ldo I linked is max 14v, so I think it will be ok @ 12.6v. \$\endgroup\$
    – protoc0l
    Commented Feb 11, 2015 at 20:04
