7
Can Cell Phones be (legally) used Adhoc, (ie, Point-to-Point) Communication? For example, let's say I'm in a remote area of the woods, or a valley. Can I configure cell phones to be used as true walkie-talkies even though neither one of them use has a cell phone tower?
(Besides, it might be handy to use this on, oh, say, a drone, for photography purposes. I intend to comply with all regulations regarding use of my drone.)
This goes for those modules too, I can hook them up to a raspberry pi, for example. enter image description here
In the latter case I could just buy a nice antenna, I guess....
What kind of range would either of these things have if they are feasible?
I wanted to get my ham radio license, but I have my second year of engineering school to finish up.
Also: Might you suggest any alternatives (I hope this doesn't make my askance too open- but, it may be worth noting this question, or moreover, it's very upvotable answer! Alas, I doubt they have too much bandwidth...)
    \$\begingroup\$ Do you have a cell phone that CAN be configured to be in ad-hoc mode? I know that the cellphone providers have been discussing this recently, but AFAIK, nothing's been released. \$\endgroup\$
    – Dave Tweed
    Commented Feb 12, 2015 at 0:23
  • \$\begingroup\$ I wonder how they'll justify charging us for minutes in ad-hoc mode... \$\endgroup\$
    – Jon
    Commented Feb 12, 2015 at 0:43
4 Answers 4
7
No, they cannot. Cell phones contain cell modems, like the green module pictured in the question. They are controlled using "AT" commands, patterned after (but greatly extending) the AT commands developed in the original Hayes modems thirty years ago.
There is a core set of AT commands that are common across all cell modems; these generally have a prefix of "AT+". Then there are a number of proprietary AT commands developed by each cell modem manufacturer, they have prefixes like "AT$" or "AT%" etc where the third character is unique to the manufacturer.
I have worked with cell modems from four different manufacturers. The documentation for these commands typically runs over 500 pages long.
These are all designed to work with a cell tower. There is a command to get the signal strength (AT+CSQ), which is used to update the bars on the screen. There are commands to check whether the cell modem has registered on the network (connected to a cell tower). Another command to get the list of carriers supported by the cell tower.
A command to dial a call (ADT, just like the dial up modems from the past). When a call answers, the response is CONNECT. When an incoming call comes in, the modem says RING ... RING etc (sound familiar?). More commands to send SMS messages, send and receive data (used for accessing the Internet), commands to access the phone book, etc.
If these were to work for point-to-point communication with another cell phone, that other cell phone would have to have all of the capability of a cell tower. But there is no provision for that. There are no commands in any cell modem AT set which allow a cell phone to behave that way.
  • \$\begingroup\$ If it was to be possible to replace layer 2 and up in the protocol stack then I can't see any reason why it wouldn't be possible to use a phone for ad hoc links. I know there was a CDMA phone released in AU quite a few years ago that was capable of doing this, although it vanished fairly quickly. I assume that phone co's did/would hate the idea! \$\endgroup\$
    – markt
    Commented Feb 12, 2015 at 2:08
    \$\begingroup\$ @markt And how are you going to write your own code for the cell modem? This option is not available even if you knew how. The microcontrollers in some cell modems can run user code, but this is in a protected space and all of the cell stuff is still hidden from the user. \$\endgroup\$
    – tcrosley
    Commented Feb 12, 2015 at 2:25
  • \$\begingroup\$ I'm not saying it's easy, I'm saying that in the right circumstances it's not impossible. I suspect half the reason you can't access the modem is to prevent people doing exactly this. \$\endgroup\$
    – markt
    Commented Feb 12, 2015 at 2:27
  • \$\begingroup\$ @markt I totally agree. \$\endgroup\$
    – tcrosley
    Commented Feb 12, 2015 at 2:28
There are apps that let you connect to WiFi and form ad hoc.
There is a device called a Beartooth that will serve as the cell tower It comes with the phone then uses 900mhz
Open source software called lifenet allows for zero infrastructure ad hoc networks etc.
It is possible, and has been commercialized by GoTenna. The review aren't stellar. It does not contain voice or pictures, but text messaging and GPS are functional.
I dont believe it actually uses the phones antenna though, but rather it's own under MURS frequencies. It just uses the phones screen as a GUI and has it's own system.
  • \$\begingroup\$ GoTenna is an external device. \$\endgroup\$ Commented Jun 18, 2016 at 21:16
    \$\begingroup\$ And it's doing all the radio communications itself. None of the smartphone's radio capabilities are involved, besides Bluetooth (which it only uses to communicate with the GoTenna). \$\endgroup\$
    – user39382
    Commented Jun 18, 2016 at 21:44
  • \$\begingroup\$ this answer doesn't utilize the phone's own functionality, but relies on an external device's functionality \$\endgroup\$ Commented Jul 23, 2017 at 19:48
Actually there have been phones that could probably be convinced to play this way, the Motorola C123 springs to mind, but you need some smt skills to hardware hack the TX output filters.
The usual use case is using the thing as a BTS in its own right, often with openBTS or the like as a protocol analysis and debug tool, but you could probably come up with a way to have it work (horribly inefficiently) in a mesh.
The nice thing about this particular phone is that the RF interface has been comprehensively reversed, so unlike most the real low level RF stuff is available (PLL settings, modulation, the whole lot).
