I have started working on HLK-m30 WiFi module. I am developing the simple client on the module using simple AT commands. I have Opened socket TCP client and then Write data using the command.
GET / HTTP/1.1
Host: www.google.com
when I read socket using AT command it shows me 0:ok. whereas 0 is Socket number and ok is response of command but not receiving any data. Also I am not able to make it work on transparent transmission mode. when I am reading Socket query, Using at+SL command. I got this:
at+SL=?
0:2,3
1:0,0
2:0,0
3:0,0
If anyone here as worked on this module please guide me.
EDIT1:
I have written a code on ATmega16 which open socket, write to it and receive or read socket. I am sending http get request to a server but not able to receive the response back. What can be the problem? here is my code:
 * ATmega16_HLK_m30.c
 * Created: 03-03-2015 16:12:22
 *  Author: B2
#ifndef F_CPU
#define F_CPU 16000000UL // or whatever may be your frequency
#endif
#include <avr/io.h>
#include <util/delay.h>
#include <string.h>
#include <avr/eeprom.h>
#include "usart.h"
#include "dbg_putchar.h"
char buffer[255];
const char AT[]="at";
const char AT_WC[] = "at+WC=";                                                  //Calculation PMK
const char AT_DHCP[] = "at+dhcp=";                                              //Set DHCP or static IP
const char AT_UTYPE[] = "at+UType=";                                            //Set TCP or UDP
const char AT_UIP[] = "at+UIp=";                                                //Set remote IP address
const char AT_URPORT[] = "at+URPort=";                                          //Set remote port
const char AT_ULPORT[] = "at+ULPort=";                                          //Set local port
const char AT_REBOOT[] = "at+Rb=";                                              //Reboot module
const char AT_VERSION[] = "at+ver=";                                            //Get version
const char AT_DEFAULT[] = "at+Df=";                                             //Back to default settings
const char AT_SO[] = "at+SO=";                                                  //Socket open
const char AT_SC[] = "at+SC=";                                                  //Socket close
const char AT_SL[] = "at+SL=";                                                  //Socket check
const char AT_SW[] = "at+SW=";                                                  //Socket write
const char AT_SR[] = "at+SR=";                                                  //Socket read
const char AT_DR[] = "at+DR=";                                                  //Domain name resolution
const char AT_GPW[] = "at+GW=";                                                 //GPIO write
const char AT_GPR[] = "at+GR=";                                                 //GPIO read
const char AT_TS[] = "at+TS=";                                                  //Transparent transmission change
const char AT_MAC[] = "at+mac=";
char HttpRequest[] = "GET / HTTP/1.1\r\nHost: www.google.com\r\n\r\n";
uint8_t hlkM30SendCmd(char *,char *);   //Send Command
uint8_t hlkM30AT();                     //send at and check connection
uint8_t hlkM30_Dhcp();                  //Configure module with dynamic IP
uint8_t hlkM30TCPClient();              //Set TCP Client
uint8_t hlkM30LocalPort();              //Set local Port
uint8_t hlkM30RemotePort();             //Set Remote Port
uint8_t hlkM30PMK();                    //Calculate PMK
uint8_t hlkM30Reboot();                 //Reboot
uint8_t hlkM30OpenSocket();             //Open Socket
uint8_t hlkM30ListSocket();             //List Socket
uint8_t hlkM30WriteSocket();            //Write Socket
uint8_t hlkM30ReadSocket();             //Read  Socket
uint8_t hlkM30CloseSocket();            //Close Socket
int main(void)
    USARTInit(9600);
    dbg_tx_init();
    dbg_puts("HLK-M30 Test\r\n");
    //hlkM30Init();
    hlkM30AT();
    hlkM30_Dhcp();
    hlkM30TCPClient();
    hlkM30LocalPort();
    hlkM30RemotePort();
    //hlkM30CloseSocket();
    //hlkM30OpenSocket();
    hlkM30ListSocket();
    hlkM30ReadSocket();
    //hlkM30PMK();*/
uint8_t hlkM30SendCmd(char *cmd,char *val)
    UWriteString(cmd);
    UWriteString(val);
    UWriteData(0x0D);
uint8_t hlkM30AT()
        uint8_t len=0;
        uint16_t i=0;
        len=strlen(AT);
        UFlushBuffer();
        hlkM30SendCmd(AT,"\r");
        //UWriteString(AT);
        //Wait for echo
        _delay_ms(300);
        while(i<10*len)
            if(UDataAvailable()<len)
                i++;
                //dbg_putchar('.');
                _delay_ms(10);
                continue;
            else
                //We got an echo
                //Now check it
                UReadBuffer(buffer,len);    //Read serial Dat
                //UWriteString(buffer);
                dbg_puts(buffer);
    uint8_t len=0;
    uint16_t i=0;
    len=strlen(AT_DHCP);
    UFlushBuffer();
    hlkM30SendCmd(AT_DHCP,"1\r");
    //Wait for echo
    _delay_ms(300);
    while(i<10*len)
            i++;
            //dbg_putchar('.');
            _delay_ms(10);
            continue;
        else
            //We got an echo
            //Now check it
            dbg_puts(buffer);
    uint8_t len=0;
    uint16_t i=0;
    len=strlen(AT_UTYPE);
    UFlushBuffer();
    hlkM30SendCmd(AT_UTYPE,"2\r");
    //Wait for echo
    _delay_ms(300);
    while(i<10*len)
            i++;
            //dbg_putchar('.');
            _delay_ms(10);
            continue;
        else
            //We got an echo
            //Now check it
            UReadBuffer(buffer,10); //Read serial Dat
            dbg_puts(buffer);
    uint8_t len=0;
    uint16_t i=0;
    len=strlen(AT_ULPORT);
    UFlushBuffer();
    hlkM30SendCmd(AT_ULPORT,"80\r");
    //Wait for echo
    _delay_ms(300);
    while(i<10*len)
            i++;
            //dbg_putchar('.');
            _delay_ms(10);
            continue;
        else
            //We got an echo
            //Now check it
            UReadBuffer(buffer,17); //Read serial Dat
            dbg_puts(buffer);
    uint8_t len=0;
    uint16_t i=0;
    len=strlen(AT_URPORT);
    UFlushBuffer();
    hlkM30SendCmd(AT_URPORT,"80\r");
    //Wait for echo
    _delay_ms(300);
    while(i<10*len)
            i++;
            //dbg_putchar('.');
            _delay_ms(10);
            continue;
        else
            //We got an echo
            //Now check it
            UReadBuffer(buffer,19); //Read serial Dat
            dbg_puts(buffer);
uint8_t hlkM30PMK()
    uint8_t len=0;
    uint16_t i=0;
    len=strlen(AT_WC);
    UFlushBuffer();
    hlkM30SendCmd(AT_WC,"1\r");
    //Wait for echo
    _delay_ms(300);
    while(i<10*len)
            i++;
            //dbg_putchar('.');
            _delay_ms(10);
            continue;
        else
            //We got an echo
            //Now check it
            UReadBuffer(buffer,7);  //Read serial Dat
            dbg_puts(buffer);
    uint8_t len=0;
    uint16_t i=0;
    len=strlen(AT_SO);
    UFlushBuffer();
    hlkM30SendCmd(AT_SO,"2,www.stealmylogin.com,80,80\r");
    //Wait for echo
    _delay_ms(300);
    while(i<10*len)
            i++;
            //dbg_putchar('.');
            _delay_ms(10);
            continue;
        else
            //We got an echo
            //Now check it
            UReadBuffer(buffer,25); //Read serial Dat
            dbg_puts(buffer);
        uint8_t len=0;
        uint16_t i=0;
        len=strlen(AT_SL);
        UFlushBuffer();
        hlkM30SendCmd(AT_SL,"?\r");
        //Wait for echo
        _delay_ms(300);
        while(i<10*len)
                i++;
                //dbg_putchar('.');
                _delay_ms(10);
                continue;
            else
                //We got an echo
                //Now check it
                UReadBuffer(buffer,20); //Read serial Dat
                dbg_puts(buffer);
uint8_t hlkM30CloseSocket()     //Close Socket
    uint8_t len=0;
    uint16_t i=0;
    len=strlen(AT_SC);
    UFlushBuffer();
    hlkM30SendCmd(AT_SC,"0\r");
    //Wait for echo
    _delay_ms(300);
    while(i<10*len)
            i++;
            //dbg_putchar('.');
            _delay_ms(10);
            continue;
        else
            //We got an echo
            //Now check it
            dbg_puts(buffer);
    uint8_t len=0;
    uint16_t i=0;
    len=strlen(AT_SW);
    //char str[];
    UFlushBuffer();
    hlkM30SendCmd(AT_SW,"0,,\"GET / HTTP/1.1\r\nHost: www.stealmylogin.com\r\n\r\n\"\r");
    //hlkM30SendCmd(AT_SW,"0,,\"GET / HTTP/1.1\n\r\"\r");
    //Wait for echo
    _delay_ms(300);
    while(i<1000)
            i++;
            //dbg_putchar('.');
            _delay_ms(10);
            continue;
        else
            //We got an echo
            //Now check it
            UReadBuffer(buffer,50); //Read serial Data
            dbg_puts(buffer);
uint8_t hlkM30ReadSocket()              //Read  Socket
    uint8_t len=0;
    uint16_t i=0;
    len=strlen(AT_SR);
    //char str[];
    UFlushBuffer();
    hlkM30SendCmd(AT_SR,"0,50\r");
    //Wait for echo
    _delay_ms(300);
    while(i<10*len)
            i++;
            //dbg_putchar('.');
            _delay_ms(10);
            continue;
        else
            //We got an echo
            //Now check it
            dbg_puts(buffer);
here is the Log which I received:
HLK-M30 Test
at
at+dhcp=1
ok
at+UType=2
ok
at+ULPort=80
at+URPort=80
ok
at+SL=?
0:2,3
1:0,0
2:0,0
3:0,0
at+SW=0,,"GET / HTTP/1.1
ok
almylogin.com
ok
at+SR=0,50
0:ok
I dont understand what to do the next step? How can I send receive from server?
  • \$\begingroup\$ need motivation guys. \$\endgroup\$
    – isoln
    Feb 27, 2015 at 14:24
  • \$\begingroup\$ Hi there?Need to develope a TCP client on HLK-m30 with ATmega16 micro controller. \$\endgroup\$
    – isoln
    Mar 5, 2015 at 11:00
Problem Has been solved. the configuration was correct. After reset the module, it gets connect to server and start send/receive data.
