43
I go through this every time I have PCBs I need to populate with SMD parts, and this has become more an issue as pin spacings have gotten tighter, and my hands have become less steady with age.
So far I've modified some curved tweezers with a rubber band for grip tension, to help hold a component in place until 1 or 2 pins can be soldered. It works but it can be cumbersome. The clamping force needs to be very light, and it seems one slight tap with a sharp iron tip will still move it. I've also tried various glues, placing a pin drop of glue in the center of where a component would go.
That sometimes works, but all the glues I've tried either waste my time waiting for it to dry, or dry (skin over) too quickly when grabbing some more. Worse, too often even a pin drop of glue will spread onto the pads, and then I have to waste more time cleaning things up.
If I had my druthers, all SMD pars would come with peel off self stick backing. But anyway, suggestions would be welcome. It will be a long time and many test markets before anything I'm doing will be populated for me with pro pick and place machines.
    \$\begingroup\$ This is a "What's the best ___?"-type of question and will be moderated soon. Personally, since the one-offs are just for me to debug before having a pick-and-place shop make a bunch, I just make the pads protrude past the chip's edge so that I have room to hit them with a fine-tipped iron. This trick will help even if you attempt to reflow first. \$\endgroup\$
    – Jon
    Feb 12, 2015 at 18:58
  • 4
    \$\begingroup\$ This is a wiki type post that has every valid reason to be here. There are a couple others like this too. \$\endgroup\$
    – Passerby
    Feb 12, 2015 at 19:49
  • 11
    \$\begingroup\$ This absolutely looks like a good question to me. \$\endgroup\$
    – Greg d'Eon
    Feb 12, 2015 at 19:50
    \$\begingroup\$ @jon Yes! If you're planning to hand-solder, Do Not use the recommended footprints! They're for paste, stencil and reflow. Add 0.5 to 0.7 mm to the ends of the pad, so you can get the iron in there. The component won't self-centre so well, but that's OK, you're holding it down. \$\endgroup\$
    – tomnexus
    Feb 12, 2015 at 21:31
    \$\begingroup\$ And I thought I was the only one making my own footprints with longer pads. :-). But still, it would be nice if the parts could just be made to stay put better while you work. So good ideas kicked in about past methods with hat air or oven, and I'll definitely have to try it. But a glue with a very high viscosity that stick quickly without drying up while your applying would still be a welcome product. \$\endgroup\$
    – Randy
    Feb 12, 2015 at 23:32
9 Answers 9
24
I just saw the SMD beak on Hack-a-day that looks like what you are looking for (I want one!)...
http://vpapanik.blogspot.de/2015/02/the-smd-beak.html
I've also had luck...
  1. use a little piece of scotch or painter's tape on one side of a part to hold it down
  2. tack down a couple of leads with solder
  3. remove tape and solder down properly
For smaller parts (ie. SOT23)...
  1. tin one pad (typically a middle one)
  2. hold the part in exactly the right place with tweeters
  3. quickly touch the lead over the tinned pad with your iron to tack it down
  4. properly solder the other pins and work your way around back to the tacked one.
A nice feature of this technique is that you can rotate the part very precisely by moving your elbow (your arm acts like a big leaver). Even if you are a bit shaky, you can wait until the part happens to be perfectly aligned and then lock it down with the tack.
    \$\begingroup\$ Oh that's a cool thing. Some reverse tweezers as the tip would be nice since they'd work just like a normal beak when closed. \$\endgroup\$
    – Samuel
    Feb 12, 2015 at 20:02
    \$\begingroup\$ I love the beak! I'm going to go make one right now :) \$\endgroup\$
    – bitsmack
    Feb 12, 2015 at 20:16
    \$\begingroup\$ The beak! What a cool idea! I'm gonna make one and try it out. \$\endgroup\$
    – Randy
    Feb 12, 2015 at 23:40
26
Pssshh to the guys using stencils :) Bet I can put a QFP down faster than you can paste, place, and re-flow :) Although it's nice if you want to get that center pad soldered.
Seriously though if we're talking ICs here I just flux pen a little, then put some solder on one pin in the corner. Then put the chip near it. Now just flow the solder with your iron and nudge it into place with a pick, tweezers or the finger whatever works for that part. Then you can align all the other sides by heating the solder a little and nudging it. Then tack the opposite corner and off you go.
Don't waste time trying to align then solder, align while you solder.
For little guys like a SOT-23 or a 0201 I usually first put a bit of solder on one pad then heat it up and slide one pad of the component in with the tweezers. Pull the iron off and it stays in place, you can use as much force on the tweezers as you need to. Then just finish up the other pins. You can go pretty fast with this if you're placing multiple parts just prepare one pad on each footprint, then slide in the parts and then go back and do the other pins.
That's my basic hand technique, works for QFNs too if you don't need the center pad soldered (the board needs to be on an angle). I usually drag solder the IC's which is really fast when you get the hang of it.
For my stencil friends, you should see that new printer on kickstarter that puts down solder paste...
    \$\begingroup\$ 1 QFP? Probably. 3+ QFP? Nope. Hand soldering doesn't scale for complex boards. \$\endgroup\$ Feb 12, 2015 at 19:12
  • \$\begingroup\$ I know I'm joking, although depends how cheap your labor is... Also complex boards go to the assembly house. \$\endgroup\$ Feb 12, 2015 at 19:14
    \$\begingroup\$ Most of my boards are still well under 100 parts. My problem is that the techniques you are describing worked well for me up until about the last 10 years. Now, just from age I guess, I find my dexterity and steadiness to be getting worse. The vision part is easy... just use a magnifier. But for the placement while soldering, I sure do wish there were some product that would let me get my parts placed and then HOLD it. For me, trying to move a part into place while I'm heating is just becoming unworkable. \$\endgroup\$
    – Randy
    Feb 12, 2015 at 23:37
  • \$\begingroup\$ Interesting that could be tough even trying the solder paste route. Although look at something like this github.com/celer/picktor it's an attachment to a 3d printer that let's you pick and place. Also this reminds me of a probe station I looked at. Take a look at this from gigaprobes gigaprobes.com/probemanipulators.html You may not need something that fancy (I made one out of an erector set instead of buying it). \$\endgroup\$ Feb 12, 2015 at 23:56
  • \$\begingroup\$ but if you had something where you could adjust the holding arm to the side of your microscope, then you could use this to dial it into the exact right position. Just some thoughts, with tweezers on the end of one of these arms it might work well. After you get it grossly in position there are little knobs to fine tune x,y,z position. \$\endgroup\$ Feb 12, 2015 at 23:58
14
In general I don't hand solder any more. There's a few components though that I do still prefer to do by hand, such as 0.5mm pitch TQFPs or TSSOPs (the really fine ones) - unless I have a stencil of course. For those I just hold it down with my finger until two pins have been tacked down, when it then holds itself in place.
Anything smaller than that gets reflowed. I can't stress how much easier it is to use solder paste and a reflow workstation (or oven for full boards) instead of a soldering iron.
    \$\begingroup\$ I will try it. So far I've only used my re-flow station for removing parts, when I have no choice but to replace a defective. I'm always so worried about scorching parts or ruining them to solder them down. I'd also heard that paste has a short usable shelf life, but maybe that's not so true. Thanks for the tip. Not sure I could apply paste very neatly with my shakey hands, but it might eb easier than I think. \$\endgroup\$
    – Randy
    Feb 12, 2015 at 20:41
    \$\begingroup\$ I use it in a syringe - pretty straight forward to apply it then. I run at 240°C if I'm doing SMD LEDs, or 275°C for other things. Hotter than that can scorch the board sometimes. \$\endgroup\$
    – Majenko
    Feb 12, 2015 at 20:51
  • \$\begingroup\$ Using an air powered syringe (controlled by a foot pedal) probably gives you better control than one you press by hand - but I'm just guessing, I've never used a manual one. \$\endgroup\$ Feb 12, 2015 at 22:34
    \$\begingroup\$ You don't necessarily have to put a tiny bead on each pad. If you put a line of paste along a row of pads, when it melts surface tension will pull it onto each pad, especially if you heat it evenly with hot air. The surface tension also tends to pull the part into alignment. It's really neat - check out some of the many YouTube videos on the subject. \$\endgroup\$ Feb 14, 2015 at 22:21
    \$\begingroup\$ Well its probably my lack of experience, but just a warning to others who could make the same mistake. I went to mouser, my favorite distributor, entered "solder paste" in their product search, the top product was a no clean solder paste in a syringe. Well it came today, and its nothing but thick flux in a syringe... no solder in this stuff at all. maybe they categorized the product wrong, or maybe "solder paste" is not a sufficient description, but that was a few days wasted and a disappointment. Any specific product recommendations would be appreciated so i don't make the same mistake. \$\endgroup\$
    – Randy
    Feb 17, 2015 at 20:35
11
I wrote an article on soldering SMDs for the (Amateur) Radio Society of Great Britain magazine, RadCom, and include here some of the photographs from it that illustrate my methods of holding SMDs down. I like to have them securely clamped, with both hands free for soldering.
They show a wooden toothpick for SMDs that will sit nicely on the pads, and a close-up; how I use tweezers so that my hands are free, for SMDs that tend to slide off the pads; and how for ICs I cut a tight fitting piece of plastic as a clamp In this last picture the hole in the cardboard holds the IC upside down so that I can tin the pins.Finally an overall view of my workstation. Since taking those pictures I have replaced the small fan, to disperse the smoke, with a larger fan and filter.
My impromptu jig .... close upusing tweezersA clamp for ICs .... in usemy workstation
    \$\begingroup\$ That green notch tool holding the AD9851 ... I'll bet there will be more than one who wants the gerbers for it, or would pay money to have a set of them. Sparkfun, anyone? \$\endgroup\$
    – Damien
    Mar 1, 2015 at 0:30
  • \$\begingroup\$ As hinted in the text in my answer, the "green notch tool" was cut, with a craft knife, from a piece of plastic, which itself was the cover of a discarded A4 file. Cut slightly too narrow at first and pared wider until it just held the chip firmly. It's only needed until one pin is soldered, then the chip is held down with a finger while the tool is removed, and, after a check that the IC is in the right place, the rest of the pins can be carefully soldered. \$\endgroup\$ Mar 2, 2015 at 15:10
9
Solder paste!
Don't use an iron: get a cheap reflow oven or a toaster oven. I use a toaster oven for whole PC boards and hot air if I screw up and need to remove/replace a single component.
Doing it with a solder iron is possible, but even there I'd use solder paste. The paste works really well to hold the part in place while you solder it.
    \$\begingroup\$ Thanks. I have a reflow station, and I guess I have to overcome my fear of burning things to hell. :-) Can you recommend an easy way to apply it? Maybe its possible to get solder paste in some kind of hypdermic like applicator, with a tiny end to make tiny blobs with? \$\endgroup\$
    – Randy
    Feb 12, 2015 at 20:44
  • \$\begingroup\$ Yes, it often comes in a syringe. Be sure to get some tips for the syringe. \$\endgroup\$ Feb 12, 2015 at 22:35
  • \$\begingroup\$ I've already commented this to someone else, but just how do YOU do this without a stencil? \$\endgroup\$
    – Randy
    Feb 13, 2015 at 18:22
  • \$\begingroup\$ What Jeanne said: it comes in a syringe. Make sure your syringe has a tip. You get the hang of dispensing the right amount pretty quickly and I'd also get a small flux pen. Otherwise OSH Stencils is very cheap and good quality. \$\endgroup\$
    – lyndon
    Feb 14, 2015 at 0:13
  • \$\begingroup\$ If you're worried about overheating one particular part while placing another right next to it, you could make a little shield for it out of tinfoil. \$\endgroup\$ Feb 14, 2015 at 22:32
6
Get yourself some reverse tweezers (squeeze to open).
I don't use it every time because I'm fairly steady with tweezers + part in one hand and soldering iron in the other, but a helping-hands holding a pair of reverse tweezers holding the part seems to work.
Basically, have one of these guys:
Hold a pair of these: enter image description here
That are holding this:
If you let the helping hands grip a little high on the tweezers then they can kind of lean on the part to push it down on the board. This works best when you have the board in a vice that holds it at an angle, but can work flat on the bench too.
  • \$\begingroup\$ I have a pair of reverse tweezers, though not curved for SMD work as that bottom one you showed. Who makes that tool? \$\endgroup\$
    – Randy
    Feb 12, 2015 at 23:42
    \$\begingroup\$ sparkfun.com/products/12572 \$\endgroup\$
    – Jon
    Feb 13, 2015 at 1:51
  • \$\begingroup\$ @Randy It's the link above the picture. Or the pair Jon linked. Be advised that if you ever want to use them for 0402s or 0201s, anti-magnetic and anti-static are a must. \$\endgroup\$
    – Samuel
    Feb 13, 2015 at 2:09
  • \$\begingroup\$ Thanks. Well for all the reasons pertaining to my decreasing dexterity, I've decided to avoid discrete smaller than 805, and pin pitch less than 50 mils. But then there are these pesky parts with 30 mill spacing. For static, one of the great things about living in Florida (totally different from when I lived in NY), static is way way lower due to the higher RH (I guess). I dare say I've not fried one chip due to static since I moved here! :-) \$\endgroup\$
    – Randy
    Feb 13, 2015 at 18:25
Despite having shaky hands and old eyes I use reading glasses and tweezers to solder SMD. I first solder one pad (usually middle). I rest my left hand on the bench with tweezers holding SMD device. With right hand I use soldering iron to melt solder on pad.
Some Hardware Guy mentioned it in passing, but I want to re-iterate: Flux is your friend. The smallest possible smear of rosin (only) flux is slightly sticky. Think about a baseball pitcher's hand. Unlike glue, you can readily solder through the rosin smear. It helps instead of hurts.
  • \$\begingroup\$ True and thanks! I though I was one of the few that even used that old thick soldering paste. It does help, though it can add to your cleanup tasks later. At this point though, I've become convinced by folks here of the beauty of using solder paste (the kind with pulverized solder) along with a hot air reflow tool (or even just a toaster oven). Boy has this improved my build efficiency (and neatness!) :-) \$\endgroup\$
    – Randy
    Sep 13, 2016 at 17:29
I have used thermal (heatsink) glue to temporarily hold down larger ICs. It's probably preferable that than other glues (thermally insulating) or rosin (thermally insulating and varyingly corrosive). Just a tiny bit is needed, it is viscous and repositionable for a while. However, it might make desoldering harder - although it's not a particularly strong glue, so YMMV).
I considered an XY table of a milling machine to finely position things, or for moving a tool (eg tweezers). There are some very small, remarkably cheap ones available (eBay, Amazon). For a similar price, there are also microscope XY platforms that could probably be used.
enter image description hereenter image description here
And slightly off topic but really insteresting is this expensive manual pick-and-place jig, the CIF V900120:
There is even a version with a close-up camera and TFT screen to help fine positioning.
