I recently purchased an Adam 6050 module and need to power it up. However the manual seems a little vague, other than mentioning that it has a 10-30 volt unregulated power range. And that it consumes 2W at 24V.
Near the bottom of the manual I found a note saying to use the power module PWR-244 as an FCC approved power source. That power module is listed as having an output of 24V and 4.2 A max.
I have a little AC/DC power adapter that I can plug into the wall that outputs 24V and 800 mA. I don't think I will blow up the adam module with that, am I correct? The worst case scenario I can come up with is that it won't work because the adam module might need more ampers to function.
