I want to measure voltage between points A and B. Let's assume that there's some obstruction/difficulty in simply attaching cables between those points. Is it possible to measure the voltage wirelessly somehow?
I had an idea of a device that measures voltage at some point with reference to an on-board stable potential S. Let's say two such devices are attached to points A and B:
Device 1 measures voltage between A and S
Device 2 measures voltage between B and S
Measurements are then transmitted wirelessly to a server. Is it possible to "substitute for S" and recover voltage between A and B?
Thank you in advance for your answers :-)
