If the same channel-width is allocated for a WiFi channel and also for a Sub-1 GHz channel, would the maximum allowable speed be the same for both channels theoretically?
If they differ, what is the theory behind the same?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityIf the channel width and SNR are the same, then the channel capacity in bits per second is the same.
