-1
I'm holding a connector that looks just like a 4-pin mini din male plug, except that the plastic prong is in the wrong place and there is an extra metal strip, wide, thin and too short to be a pin, where the standard mini din plastic prong should be.
It is used to connect the pedals to the main body in my Korg EC310 digital piano.
unknown connector
different angle
    \$\begingroup\$ Are you in a concrete building? My psychic powers seem to be too weak today to have a look at the plug, maybe put it outside so I can try again? \$\endgroup\$ – PlasmaHH Feb 17 '15 at 10:56
  • \$\begingroup\$ @PlasmaHH Sorry about that. Pics added. \$\endgroup\$ – João Mendes Feb 17 '15 at 11:00
  • \$\begingroup\$ Can you give us a photo of the outside of the plug too? \$\endgroup\$ – Will Feb 17 '15 at 11:05
  • \$\begingroup\$ @Will It was shredded and in the garbage, but I recovered it for you. Here you go. \$\endgroup\$ – João Mendes Feb 17 '15 at 11:19
  • \$\begingroup\$ Might be compaitble with an s-video connector as its a mini din with a flat blade where yours is. No lump in the middle though \$\endgroup\$ – Will Feb 17 '15 at 12:13
Turns out this was a lot simpler than I thought.
That horizontal metal tab is not a tab, but a bent pin, only it was so bent that only after removing the plug shell were we able to see it.
The plug is a plain old 5-pin mini-DIN.
| improve this answer | |
