I'm using a PIC24H Microchip microcontroller to communicate via UART with a Bluetooth Module. The Bluetooth module's baud rate can be configured at runtime via software (over bluetooth or over UART) and the baud rate will change after a power cycle.
Unfortunately the only way for the microcontroller to find out what baud rate the Bluetooth module's UART is using is by asking it--over UART.
Is there a way that I can have the microcontroller test (maybe by trial and error) what the baud rate of the bluetooth module is set to? It can only be a limited set of values and will probably be set to either 115K or 230K if that makes it easier.
I once had a similar problem with a microcontroller which didn't have a UART nor exactly known clock frequency (crystal was too expensive). I let the other party send a specific byte, for instance 0x01 and measured the time the bus was low. This was 8 bit times (startbit + 7 zeros of data). So dividing this by 8 I got the value I should set my timer to.
So, before you configure the I/O pins for UART use them as common I/O until the Bluetooth module sent this agreed upon character and time it. You could do this running a loop, or use timer capture to detect the falling and rising edges (more accurate).
    \$\begingroup\$ One tip: in 8N1 the character U happens to send a nice half-baud clock signal (1010101010) which you could time and then halve to get the bit time (1/baud) \$\endgroup\$
    – Majenko
    Commented Jun 17, 2011 at 18:25
  • \$\begingroup\$ I'm not sure I could get the bluetooth module to send a byte like you describe, but that's an interesting idea. \$\endgroup\$ Commented Jun 17, 2011 at 18:27
  • \$\begingroup\$ @Matt's on the right track. Isn't this a mode of some UARTs on PICs? \$\endgroup\$
    – kenny
    Commented Jun 17, 2011 at 22:39
  • \$\begingroup\$ @kenny for receiving, yes, if it's one with the EUSART \$\endgroup\$
    – Majenko
    Commented Jun 17, 2011 at 23:23
    \$\begingroup\$ @Matt - I chose the longer sequence because it gives a result one order of magnitude more accurate. Dividing by 8 is just shifting 3 bits. But any character will do. \$\endgroup\$
    – stevenvh
    Commented Jun 18, 2011 at 6:16
