I would like the sensor values to be updated each 10ms(100Hz) and then run the algorithm and repeat the same process. However, after timing the algorithm it is taking only 2ms, I think the data_ready interrupt is not working as expected. Physical hardware connection is from INT1 of ADXL345 to pin2 of the UNO.
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_ADXL345_U.h>
#include <avr/io.h>
#include <avr/power.h>
#define F_CPU 16000000UL
volatile int sensor_update=0;
//Write to ADXL345 registers
void writeTo(int device, byte address, byte val) {
   Wire.beginTransmission(device); //start transmission to device
   Wire.write(address);        // send register address
   Wire.write(val);        // send value to write
   Wire.endTransmission(); //end transmission
//ISR function
  void interrupt(void){
  sensor_update=1;
void buzz(int targetPin, long frequency, long length) {
  long delayValue = 1000000/frequency/2; // calculate the delay value between transitions
  //// 1 second's worth of microseconds, divided by the frequency, then split in half since
  //// there are two phases to each cycle
  long numCycles = frequency * length/ 1000; // calculate the number of cycles for proper timing
  //// multiply frequency, which is really cycles per second, by the number of seconds to
  //// get the total number of cycles to produce
  for (long i=0; i < numCycles; i++){ // for the calculated length of time...
    digitalWrite(targetPin,HIGH); // write the buzzer pin high to push out the diaphram
    delayMicroseconds(delayValue); // wait for the calculated delay value
    digitalWrite(targetPin,LOW); // write the buzzer pin low to pull back the diaphram
    delayMicroseconds(delayValue); // wait againf or the calculated delay value
/* Assign a unique ID to this sensor at the same time */
Adafruit_ADXL345_Unified accel = Adafruit_ADXL345_Unified(12345);
void setup(void)
  if (F_CPU == 16000000) clock_prescale_set(clock_div_1);
  Serial.begin(9600);
  //Serial.println("Accelerometer Test"); Serial.println("");
  pinMode(4, OUTPUT);// buzzer output pin
  /* Initialise the sensor */
  if(!accel.begin())
    /* There was a problem detecting the ADXL345 ... check your connections */
    //Serial.println("Ooops, no ADXL345 detected ... Check your wiring!");
    while(1);
  /* Set the range to whatever is appropriate for your project */
  accel.setRange(ADXL345_RANGE_16_G);
  accel.setDataRate(ADXL345_DATARATE_100_HZ);
  // displaySetRange(ADXL345_RANGE_8_G);
  // displaySetRange(ADXL345_RANGE_4_G);
  // displaySetRange(ADXL345_RANGE_2_G);
  //Create an interrupt that will trigger when a tap is detected.
  attachInterrupt(0, interrupt, RISING);
  writeTo(0x1D, 0x2E, 0);
  writeTo(0x1D, 0x2F, 0);
  writeTo(0x1D, 0x2E, 128);
  writeTo(0x1D, 0x2F, 127);
void loop(void)
  if(sensor_update==1 ){
    //When sensor_update is set to 1 in the ISR,the algorithm process the data from the accelerometer being updated every 10ms(100Hz)
     sensor_update=0;//reset
Update:
#include <Wire.h>
#include <avr/io.h>
int state=0; //0--active detecting; 1--sleeping
int state_count=0; //sleeping trigger between 2 states
double mag[40];
int i=0;
double acc_rate[39];
int hunt_sub=0;
int exit_marker=-10,trough_marker=-30,peak_marker=-10;
byte buff[1] ;
volatile unsigned long time=0, time0=0,time_dis=0,time_array[40]={0};
//Read ADXL345 registers
void readFrom(int device, byte address, int num, byte buff[]) {
Wire.write(address);        //sends address to read from
Wire.beginTransmission(device); //start transmission to device (initiate again)
Wire.requestFrom(device, num);    // request 1 byte from device
int i = 0;
while(Wire.available())    //device may send less than requested (abnormal)
buff[i] = Wire.read(); // receive a byte
i++;
//ISR function
sensor_update=1;
//  time0 = time;
//   time= millis();
//        time_dis=time-time0;
//        if(i<40){
//          time_array[i]=time_dis;
 //readFrom(0x53, 0x30, 1, buff); //clear interrupt
void setup(void)
Serial.begin(9600);
//pinMode(2, INPUT);
if(!accel.begin())
while(1);
accel.setDataRate(ADXL345_DATARATE_1_56_HZ);
/* Display some basic information on this sensor */
//displaySensorDetails();
/* Display additional settings (outside the scope of sensor_t) */
//displayDataRate();
//displayRange();
//Serial.println("");
writeTo(0x1D, 0x2E, 0);// disable interrupt
writeTo(0x53, 0x2F, 0); //map data_ready to INT1
writeTo(0x53, 0x2E, 128); //enable data_ready
void loop(void)
sensors_event_t event;
readFrom(0x53, 0x30, 1, buff); //read the acceleration data from the ADXL345   (device,register to read from,number of bytes,array to store in)
while(buff[0] & 0b10000000){
accel.getEvent(&event);
 Serial.print("buff: "); Serial.print(buff[0], BIN); Serial.print("  ");
 delay(10);
 mag_calculation (event.acceleration.x, event.acceleration.y, event.acceleration.z);
 detachInterrupt(0);
 //rest of algorithm is here
  • \$\begingroup\$ Might be more at home in the Arduino stackexchange \$\endgroup\$
    – I. Wolfe
    Feb 17, 2015 at 23:04
  • \$\begingroup\$ I don't see where buzz() function is called in your code. Also, why are you using delay in microseconds? Doesn't arduino library provide _delay_ms() or something similar? \$\endgroup\$
    – Ashton H.
    Feb 17, 2015 at 23:07
    \$\begingroup\$ I posted the code related to the interrupt problem I am having, others things are irrelevant \$\endgroup\$
    – user49395
    Feb 17, 2015 at 23:10
Remove this line from the loop:
/* Get a new sensor event */
  interrupt();
You don't need to call the interrupt routine. Interrupts work by interrupting the main program flow when ever an interrupt condition is met, then executing the interrupt service routine (in your case interrupt()) then back to where ever the program left off.
attachInterrupt(0, interrupt, RISING); is a function that enables an interrupt, in this case rising edge on INT0, and tells it what function to jump to (interrupt) when the interrupt condition is met.
The way you have it now, it is setting sensor_update=1; as fast as the loop can loop.
From comments:
void loop(void)
The following will loop forever if the the flag is set as buff[0] is not updated:
Instead read the data then check the flag using a do loop:
    do {
    } while(buff[0] & 0b10000000);
The rest of the code:
    delay(10);
Remove the detach interrupt, it is not needed. The MCU will clear its interrupt flag when the code enters the ISR. By detaching here, the interrupt is disabled, and if sensor_update was 0 then it would never be enabled again by your following code.
    detachInterrupt(0);
    if(sensor_update==1 ) {
Likewise remove the attach interrupt.
  • \$\begingroup\$ You probably have to read some register, e.g. data, to clear the interrupt flag on the ADXL and thus generate further interrupts. \$\endgroup\$ Feb 18, 2015 at 2:05
  • \$\begingroup\$ I am using a library to obtain the data from the ADXL that's why I am not explicitly reading any register in my code. Is there any other way of clearing the flag? \$\endgroup\$
    – user49395
    Feb 18, 2015 at 2:41
  • \$\begingroup\$ Looking at the ADXL data sheet you have to read a register to clear the interrupt pin on the device. Otherwise the pin will just stay outputting active low. There is no other way. If I understand correctly, for the DATA_READY interrupt, which you are using, this is the data registers, so using the library function that reads the data out should clear the ADXL interrupt pin. \$\endgroup\$ Feb 18, 2015 at 2:48
  • \$\begingroup\$ Yeah since I am reading the samples using the library the interrupt pin should be cleared. Not sure what's causing this.writeTo(0x1D, 0x2E, 128); //enabling DATA_READY interrupt writeTo(0x1D, 0x2F, 127); //MAP DATA_READY to INT1 INT_SOURCE register is not used \$\endgroup\$
    – user49395
    Feb 18, 2015 at 2:54
  • \$\begingroup\$ You have to explicitly read the data after if(sensor_update==1 ){, is that what you are doing? If so, please update your code. \$\endgroup\$ Feb 18, 2015 at 4:47
