Is cyanoacrylate adhesive ("superglue") conductive?
I need to repair some USB housings and I want to be sure any "overdrip" won't short the connection.
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityIs cyanoacrylate adhesive ("superglue") conductive?
No, CA glues are not conductive. They're really just a polymer just like any other plastic.
The bigger concern would be getting glue on the contacts that would prevent a good connection.
Cyanoacrylate adhesive ("unfilled" that is without carbon oder metal particle filling) is typically not conductive. You do not need to be afraid of short circuits.
There might however be issues of long term corrosion if the glue interacts with wiring on the printed ciruit board. While I cannot find any solid evidence on this (other than entries in various newsgroups with no scientific backing), GlobalSpec explicitely lists "Non-corrosive Cure Cyanoacrylate Adhesives", at least suggesting that there might be types cyanoacrylates that show corrosive behaviour during curing and/or later use.
While normal 'superglue' isn't conductive and won't cause shorts, I've had trouble in the past with superglue vapor causing non-conductive deposits on nearby contacts.
Since you're planning to repair connectors you'll need to be aware of this if you suddenly find that they're not connecting as well as they used to ...
A little further proof/information Loctite Tak Pak 444 is basically cyanoacrylate, and it's marketed specifically for electronics. I've been using it for years doing exactly what you're talking about, and it's definitely not conductive. It's also the preferred rework adhesive at several of our CMs.
Oh and if you're doing a bunch of this kind of rework the accelerator makes it dry in only a few minutes.
Might consider Glass Block Sealant (tube for caulk gun) , it is (actually was) non-corrosive (no ammonia like in other caulk) and non conductive the last time I procured this sealant. Was available at Home Depot by the tube, last time I checked a couple years ago, only available by the Case at Home Depot. Amazon you can buy it by the tube. Pittsburgh Corning Corp. 11133 10.3 Oz Glass Sealant. $12.96 per tube.
