I'm working to interface with an old serial protocol. All I have actually is the frame format and various timings.
I need the baudrate to sync correctly and use the data properly.
  • My frame is 15 bits (one start, 12 data, one parity, one stop)
  • One bit is held for 10ms
  • One frame is 150ms
  • (spec says 4ms between frame, I think this is useless and it's just the change-time-rising stuff from/to 0/1)
I tried to find some calculations on the web but found nothing...
Any help for that?
Thanks.
    \$\begingroup\$ The baud rate is the inverse of the period, so for a 10ms period the baud rate is 100. That said, I doubt you'll find a (hardware) serial port implementation that will deal with a frame of that size. You'll probably need to write a soft UART in an MCU. \$\endgroup\$ – markt Feb 19 '15 at 9:10
Baud rate is the inverse of a single (data) bit time. So the start, stop, or other framing doesn't actually come into the calculation.
So, the answer for you is simply 100 Baud.
