I'm going to clock an MSP430FR5969 using a PCF2127 RTC. The PCF2127 can output 32.768kHz at a duty cycle between 40%-60% and 16.384kHz, 8.192kHz, etc at exactly 50%. I will use the MSP's DCO system to generate an 8Mhz internal clock from this LF input.
Will the variable duty cycle @ 32.768kHz be a problem or should I change the RTC output to 16.384kHz to guarantee a 50% duty cycle?
