#include<reg51.h>
     sbit sw=P1^0;
     sbit led=P1^1;
    void write(unsigned char m);
     void delay(unsigned char k);
     void main(){
      while(1){
        delay(60);
         sw=1;
         led=0;
         if(sw==1){
           delay(50);
           write(1);}
          else{
           delay(50);
           write(0);}
           void write(unsigned char m){
              led=m;}
           void delay(unsigned char i)
           { unsigned int k,l;
           for(l=0;l<=i;l++)
           for(k=0;k<65500;k++);
what value is received by write function whether it is character or integer? i want to send integer value to write on led? is it right?plz tell me
  • \$\begingroup\$ How is led defined? \$\endgroup\$ Feb 20, 2015 at 14:28
  • \$\begingroup\$ why dont you use int instead of char. It is possible you will get correct output. \$\endgroup\$ Feb 20, 2015 at 14:31
  • \$\begingroup\$ led is defined as output pin \$\endgroup\$ Feb 20, 2015 at 14:31
  • \$\begingroup\$ i want to use character for decreasing memory size as character requires 1 byte and interger requires 2 bytes \$\endgroup\$ Feb 20, 2015 at 14:35
  • \$\begingroup\$ That is not a C primitive, so it leads to the next question: how is a pin defined? \$\endgroup\$ Feb 20, 2015 at 14:38
char and unsigned char are numeric types; whatever value you assign to a variable of type char or unsigned char is the value that the variable will hold. So the 0 and 1 values in the two calls are fine.
Yes, C also uses char to represent character values, but that's a convenience: it doesn't affect what values are held. If you assign 1 to a char variable, the variable holds the value 1. If you assign 'a' to a char variable, the variable holds whatever value the 'a' represents; these days it will be 97, which is the ASCII representation for 'a'.
