I cannot get PWM to work using mode 15 (a fast PWM) of timer 1. It's always giving me a high value of around 4.5V on PORTB2.
#include <avr/interrupt.h>
#define TIMER_OVERFLOW_COUNT  1
volatile int timerCount = 0;
ISR(TIMER1_COMPA_vect)
        ++timerCount;
int main(void)
        DDRB = DDRB | 1 << DDB2;
        TCCR1A = TCCR1A | 1 << COM1B1;
        TIMSK1 = TIMSK1 | 1 << OCIE1A;
        TCCR1A = TCCR1A | 1 << WGM10;
        TCCR1B = ((TCCR1B | 1 << WGM13) | 1 << WGM12) | 1 << WGM11;
        OCR1A = 62499;
        sei();
        TCCR1B = TCCR1B | 1 << CS12;
        while(1)
        if( timerCount > TIMER_OVERFLOW_COUNT)
                        OCR1B = 25000;
                        timerCount = 0;
        return 0;
However, I could get the similar mode (mode 7) of timer 0 to work fine.
#define TIMER_OVERFLOW_COUNT  125
volatile long int timerCount = 0;
ISR(TIMER0_COMPA_vect)
        ++timerCount;
int main(void)
        DDRD = DDRD | 1 << DDD5;
        TCCR0A = TCCR0A | 1 << COM0B1;
        TIMSK0 = TIMSK0 | 1 << OCIE0A;
        TCCR0A = (TCCR0A | 1 << WGM00) | 1 << WGM01;
        TCCR0B = TCCR0B | 1 << WGM02;
        OCR0A = 124;
        sei();
        TCCR0B = (TCCR0B | 1 << CS02) | 1 << CS00;
        while(1)
        if(timerCount > TIMER_OVERFLOW_COUNT)
                        OCR0B = 50;
                        timerCount = 0;
        return 0;
I cannot figure out what I am doing wrong in the earlier code.
I see one problem, but without a setup to test on: I can't say for sure if it's your only problem.
You're trying to set the WGM11 bit in TCCR1B to one when it really is in TCCR1A. Because of this, the WGM bits are 0x1101, and not 0x1111 that you want.
See below the TCCR1A register:
So this is the Waveform Generation Mode (WGM) that you are setting at.
It's "Reserved", so nothing.
You need to set WGM11 in TCCR1A:
TCCR1A |= (1 << WGM11) | (1 << WGM10);
TCCR1B |= (1 << WGM12) | (1 << WGM13);
  • \$\begingroup\$ No problem; we all make mistakes like this. \$\endgroup\$ – Nick Williams Feb 20 '15 at 19:47
