I need to use 7 strings of led, each one of a different color. I will control each string using a Arduino and the BC 337 Transistor. The string will be connected to a 12V power supply.
I have read lots of things about LED's. I think the right way is to use the string in parallel, with each string having it's own resistor, based on the voltage drop of the led in that string. So, the string blue will have a resistor and the string red will have a different one, because the voltage drop of one LED is different than the other (the colors are different).
Here is the circuit I draw. I only need to calculate each string resistor value, depending of the voltage drop of the led.
Is it right and safe to use? My only doubt is that I read in a lot of places that this kind of thing would require more complex components to regulate the voltage. And then I read a lot people saying this design is good enough.
