This question already has an answer here:
If passive components like resistor and capacitor can be integrated into an IC, why not inductor?
marked as duplicate by Keelan, Daniel Grillo, Vladimir Cravero, Scott Seidman, Matt Young Feb 24 '15 at 20:24
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
  • \$\begingroup\$ They can be, related question: electronics.stackexchange.com/questions/41931/…. Maybe flag as a duplicate if that's the answer you were looking for? \$\endgroup\$ – PeterJ Feb 21 '15 at 8:17
    \$\begingroup\$ This is actually being done and pursued for mass manufacturing. I'm not in the know, but i assume it's difficult to get useful 3d shapes to form the required magnetic fields. \$\endgroup\$ – Sean Boddy Feb 21 '15 at 8:20
They certainly can be. The problem is that they're not very well behaved. They are only used where absolutely necessary. For low frequencies, they're pretty much out of the question as they would be too large. For RF, they are used regularly to build filters and baluns and what not. However, inductors built with planar processes have lots of nasty parasitics that prevent them from being very effective. Things like parasitic capacitance can cause inductors built on ICs to have low quality factors - meaning they don't really behave like an ideal inductor, but like an RLC circuit that's 'mostly' inductor. Also, inductors are more problematic when it comes to external interference - they are more likely to cause it as well as more likely to be affected by it. It is also likely for inductors on a chip to cross-couple to each other, which is very difficult to avoid due to the physical constraints of a chip - physical separation is required to reduce magnetic coupling, but chip area is expensive.
If you want to see pictures of inductors on chips, do a google image search for RFIC or MMIC.
