I've been browsing around looking for some information on motors\servos and AVR's (my MCU of choice). Motors\servos are in my gray area, meaning I'm still not too into them, but I could do something with them if a job arose.
What I want to do is design a little "plate", if you will, that I can use for one of two things:
  1. I have a bandsaw and could really use a device that will feed and saw things for me. So an X\Y axis device that I can either control position manually, or automatically with a preset that includes size information on what I'm sawing.
  2. I also have a Dremel Press I use for my PCB's. Although I have a great eye and hit my mark perfectly 80-90%+ of the time, automating it would be fantastic. So I would put my PCB on the "plate", and the AVR would position the board at pre-programmed coordinates from like Eagle. And then another motor\servo\solenoid\something would pull the lever and drill the hole; so on and so forth.
The software aspect is no problem for me. So in the purest, most basic form, basically I just need to know the easiest\smartest\best way to use two motors to position an object on an X\Y plane using an AVR (I saw a bit about PWM, but it doesn't seem exact enough to me; maybe I'm missing something). What's the best way to determine distance per revolution with both DC and servo motors?
Thank you all, once again
Check out...
https://acidbourbon.wordpress.com/2015/02/01/semi-automated-drill-press-table-for-pcb-manufacture/
He used an ATMEGA AVR to control motors connected an X/Y table for positing PCB boards under a drill press. I think very similar to what you are trying to do. His motor circuits and software should give you a great start on your projects.
  • \$\begingroup\$ A great way to get started with this stuff is to use an Arduino (is actually just an ATMEGA AVR) with the AdaFruit Motor Shield and a couple of stepper motors. You can have something working in a few minutes! \$\endgroup\$
    – bigjosh
    Commented Feb 22, 2015 at 21:00
  • \$\begingroup\$ I have a home made Arduino that I use. And I make my own shields and boards, so I'll take a look at this and put something together. The only thing I don't have is steppers. I have some Radioshack servos (they're going out of business here, so everything was like 80% off), and SparkFun DC motors. But thanks. So do you have a recommended way of finding distance per revolution? \$\endgroup\$ Commented Feb 22, 2015 at 21:21
