I am attempting to control the gain of an amplifier circuit I am building programmatically. I am using the atmega 32 MCU to control an LCD screen and take input from some buttons. Basically, I would like to include a volume up and down button that tell the MCU to change the amplifier gain.
The amplifier circuit is shown below and the 10k pot is circled in red: amp crkit
I have thought of using a transistor to do PWM control in place of the 10k pot, but I was advised that this would not work and that I should use a resistor bank instead or perhaps a switch capacitor circuit.
Can anyone point me in the right direction, and is there any reason why I wouldnt be able to replace the potentiometer with a digital pot like this one: https://www.sparkfun.com/products/10613 ??
  • \$\begingroup\$ Why not use an amp that has digital gain control in the first place? \$\endgroup\$ Feb 23, 2015 at 1:23
  • \$\begingroup\$ why not use a digital resistor? usually they are I2C devices, with at least 256 steps, sometimes more if you pay for it. Can be linear or logarithmic. \$\endgroup\$
    – KyranF
    Feb 23, 2015 at 2:37
  • \$\begingroup\$ What exactly is the nature of the signal you're going to amplify? \$\endgroup\$
    – Matt Young
    Feb 23, 2015 at 3:44
I've used those exact pots. The datasheet is not kidding about the wiper current; don't exceed it at min/max and you should be fine.
    \$\begingroup\$ Another thing to be careful about, you aren't supposed to have voltage going through the device that is outside the supply rails, so if your audio signal is zero-centered you need to offset it before the digital pot chip. \$\endgroup\$
    – Austin
    Feb 23, 2015 at 1:25
None of the pot terminals can go below Vss. If your input doesn't go below ground you should be OK. That and the current restrictions are the factors I usually have issues with
  • \$\begingroup\$ Wow, okay, so what is the simplest way to insure that my input will be in the 0-5v input range since the pot apparently cannot handle negative input voltage? The input I have is your typical mp3 player headphone signal. \$\endgroup\$ Feb 23, 2015 at 1:58
  • \$\begingroup\$ Add an offset and another amp stage \$\endgroup\$ Feb 23, 2015 at 11:45
