I added 3 high side switches, like below schematics. And all needs to turn 5V on and off.
I have few questions about it.
  • How do I calculate the resistor values ? I have few ideas but I want to know how its done
  • How do I calculate Vout of Q3 ? I think Vout will not be 5V
  • How do I calculate the heat of both Q6 and Q3 ? because one switch load will take around 5A, another will take 1.5A and third one around 1A. And they might be ON for hours.
  • \$\begingroup\$ With a 5A load, it may be better to use a P-channel MOSFET instead of a PNP BJT. The load voltage would vary depending on many things, but a typical value for a saturated switch might be VCC = 0.2 or 0.3V. \$\endgroup\$ – mkeith Feb 23 '15 at 5:57
K.,
All the answers for your questions depends about somethings, like this:
  • What Transistor would you use?
  • You want to control the load current (limit the load current) or you want that transistors operates like a fully on switch?
To dimensionate the resistors, you will need to read the transistors datasheet, and search for the hfe or β, the amplification of the transistors. So you will use:
Ic = β.Ib, find the Ib and then find the base resistance by Ohm's Law. Remember that you need an Ib greater to the Ib calculated to operate at the fully on mode.
Finnaly, you will find a graphic like this on the transitor datasheet:
So you can obtain the Vce voltage (transistor voltage drop), after you dimensionate your base resistance (you will know Ib);
If you get your load equation in function of the variables I (Ic) and Vce, you can construct another curve into the above image, like below:
Example: If your load is a Rl resistance, you will get the equation:
I = (5 - Vce)/Rl
So you will determinate whit precision your Quiescent point, that is the point of operation of your circuit!
Just a tip: Do you know any Spice simulators? Whit them you can simulate your circuits, whit a model for each component, and discovers how your system will work at many situations, it's a very useful tool! I use the simetrix simulator!
| improve this answer | |
