I designed a board containing a USB to UART bridge in order to program a ATmega microcontroller. I copied the schematic of this breakout board from Sparkfun
https://www.sparkfun.com/products/9716
This is my schematic:
I install FTDI drivers from this link:
http://www.ftdichip.com/Drivers/VCP.htm
in "windows - setup executable". It doesn't work. My computer doesn't recognize it. I have windows 8.1 and I think it could be related. I disabled device driver signatures.
I don't know what to do now. I don't think it's related with my schematic, but I can't solve this problem.
Any idea?
Thank you.
  • \$\begingroup\$ I'm assuming you got the chip from a reputable dealer? \$\endgroup\$ Feb 23, 2015 at 17:54
  • \$\begingroup\$ Mouser I believe. I didn't assemble the board, but I gave to the manufacturer a bill of materials with Mouser part numbers as reference. \$\endgroup\$
    – zapeitor
    Feb 23, 2015 at 18:01
  • \$\begingroup\$ Does it see any new device connected (even not recognized one)? If negative I would assume hardware failure (check voltages, connections etc) \$\endgroup\$
    – Eugene Sh.
    \$\begingroup\$ What exactly does your computer do when it "doesnt recognise it"? \$\endgroup\$
    – Grant
    \$\begingroup\$ With the reset pin floating, I would be surprised if anything happened. \$\endgroup\$
    – Matt Young
    Feb 23, 2015 at 18:02
If by "my computer doesnt recognize it" you mean you can't run the exe to install the drivers, you probably have a corrupt download. Download the file again and see if it works.
If you mean the installer worked just fine, but the drivers aren't working properly, then you either hooked it up wrong, have a defective FTDI chip, or have a counterfit chip.
  • \$\begingroup\$ Hi Grant. I can install the drivers. It says installation was finished correctly. When I plug it in my computer shows a message "USB device not recognized" \$\endgroup\$
    – zapeitor
    Feb 23, 2015 at 18:10
The problem is solved. As Eugene Sh suggested, it was a problem with USB lines. I didn't assemble the board so I supossed it was properly soldered, but it wasn't. I fixed one resistor (R4 in my schematic) and now it works fine.
Were the D+/D- differential pair laid out on the PCB appropriately? Have you attempted to look at the USB enumeration with a protocol analyzer? I believe for a device to be recognized, all that needs to happen is the 1.5K pull-up is present, so I would lean towards incorrect signaling environment as the culprit.
Also, your schematics don't show an oscillator, but there are pins for an oscillator. While I'm unfamiliar with this exact part, most of the USB device ICs I have used have required a 12/24/48MHz crystal.
