6
I have a test board with 2 audio chips: WM8533 and AK4954A. Their outputs are connected to headphone plugs like that:
WM8533 -- R------ headphone1
              C
AK4954A --------- headphone2
            C
            R
So, the first one is a classical RC filter. But what is the second one? I guess it is also a low pass filter, but why it is different? I googled for RC filters, but all examples and tutorials only explain the first circuit and nobody mentioned the second one. Do you know the different and advantages of one vs another? Thanks
  • \$\begingroup\$ My guess is a pop filter? Hard to say without more context. I think something like that would suppress any sort of pop that you'd find on power-on or similar. \$\endgroup\$
    – Shamtam
    Feb 24 '15 at 3:05
  • 7
    \$\begingroup\$ Zoebel network \$\endgroup\$
    – Matt Young
    Feb 24 '15 at 3:11
    \$\begingroup\$ Boucherot Cell :-) - aka Z Zoebel network as Matt says - his reference contains the infirmatioin shown here BUT it's well buried in his version - see en.wikipedia.org/wiki/… in his reference. || \$\endgroup\$
    – Russell McMahon
    Feb 24 '15 at 9:22
  • \$\begingroup\$ Hmm - too late to edit. I could copy delete repost BUT I do like "infirmation". Goes well with "it all deep-ends" :-) \$\endgroup\$
    – Russell McMahon
    Feb 24 '15 at 9:55
10
A loudspeaker or many other inductive loads may be modelled as resistor + an inductor in series. The impedance increases with frequency.
Adding a properly dimensioned "Zoebel network" / "Bocherot cell" in parallel with the speaker etc tends to make the impedance constant (or is an attempt to).
  • Wikipedia: Boucherot cell correcting loudspeaker impedance
The capacitor causes the resistor to have increasing loading effect with increasing frequency "compensating for the series LR.
Properly designed, R = Rspeaker and C = L/R^2
Wikipedia
From here as Zoebel network OR
From here as Boucherot cell
Wikipedia:
  • A Boucherot cell (or Zobel network) is an electronic filter, used in audio amplifiers to damp high frequency oscillations that might occur in the absence of loads at high frequencies. Named after Paul Boucherot a Boucherot cell typically consists of a resistor and capacitor in series, that is usually placed across a load, for stability.1
    It is commonly seen in analog power amplifiers at the output of the driver stage, just before the output inductor. The speaker coil inductance of a loudspeaker generates a rising impedance which is worsened by the output inductor generally found in analog power amplifiers; the cell is used to limit this impedance.2
    The documentation for some power operation amplifiers suggests the use of a "Boucherot cell between outputs and ground or across the load".3
    Additionally, Boucherot cells are sometimes used across the bass driver (and mid-range) of a speaker system, in order to maintain a more constant driving point impedance as "seen" by a passive crossover. In this specific arrangement, the Boucherot cell is sometimes also known as a Zobel network.2
    Some loudspeaker crossover designs aim to stabilize impedance at high frequencies by including Zobel networks.[4]
Not just audio:
The diagram below is from page 5 in the ST data sheet referenced in ref 3 below.
It shows two x Boucherot cells used in a motor driver.
They say:
APPLICATION SUGGESTION
In order to avoid possible instability occuring into final stage the usual suggestions for the linear power stages are useful, as for instance :
  • layout accuracy ;
  • A 100nF capacitor connected between supply pins and ground ;
  • boucherot cell (0.1 to 0.2 µF + 1Ω series) between outputs and ground or across the load. With single supply operation, a resistor (1kΩ) between the output and supply pin can be necessary for stability.
(1) Rane Professional Audio Reference Home - Boucherot
(2) Rane Professional Audio Reference Home - Zobel
(3) ST, LOW DROP DUAL POWER OPERATION AMPLIFIERS, July 2003, Top of Page 5, right column. <- The original ST link on WIkipedia is broken.
(4) Bell Labs Journal: Zobel, O. J., "Theory and Design of Uniform and Composite Electric Wave Filters," Bell Sys. Tech. J., Vol. 2, pp. 1-46, Jan 1923.
