I'm trying to create a magnetic field and I'm also trying to induct electricity wirelessly to a light bulb. What I have to do is create a round coil but I'm not sure what is the most conductive material, is copper the best material for these kind of things?
1 Answer
Silver has the highest conductivity. For AC applications skin effect can come into play. Copper wires coated with silver are quite often used and litz wires (insulated bundles of very small diameter wires) are a further improvement and can counter some of the associated problems of skin effect.
To do what you are trying to do effectively usually means operating frequencies between 100kHz and 1MHz and highly resonant parallel tuned circuits. The inductance (the coil) needs a very high Q factor and the reduction of AC resistance is usually key to this.
With high Q factor coils in parallel with a resonant capacitor and a suitable driver circulating currents in the coil can easily be tens of amps and this might be the level of field strength you need to make this work at a distance of maybe 5 cm. If you want bigger distances and significant powers (tens of watts or above) this is tricky for a home spun project.
\$\begingroup\$ 5cm will be good, actually I thought to let the light bulb levitate very close to the magnetic field paired with a Hall sensor, thanks for your advice! \$\endgroup\$– MattFeb 24, 2015 at 12:49
