I don't understand the difference between a motor-driver like this IC H-Bridge Motor Driver and a motor-driver like this Dual Motor Driver Board. When reading about them they do the same thing but the second one is obviously much more complex and more expensive.
Item 1 - The L293 has two H bridges and is a chip.
Item 2 - The Ada fruit product is a circuit board with two chips and each chip has a single H bridge.
Item 1 and item 2 are functionally very similar however Item 2 has H bridges that are superior.
Item 1 is a chip that needs soldering to a PCB and item 2 is a PCB with broadly the same functionality as Item 1.
  • \$\begingroup\$ Thank you. Can you tell me why I would choose one over the other? Item 1 seems so simple and way less expensive and can run a motor up to 36v while Item 2 can run up to 28v. Why is item 2 superior? Is it just less work because of the soldering? If you can add more details that would be very helpful. \$\endgroup\$ Feb 25, 2015 at 8:51
  • \$\begingroup\$ See this electronics.stackexchange.com/questions/108686/… - it explains why the L293 is so crappy. Admittedly it does work at a higher voltage range but as far as getting any sensible amount of current from it, it's a poor choice and will overheat badly. \$\endgroup\$
    Feb 25, 2015 at 8:59
  • \$\begingroup\$ I tried reading it, that stuff is over my head at the moment. I just don't understand what all else is on these complex H Bridge PCB's when they both do the same thing. \$\endgroup\$ Feb 25, 2015 at 9:05
  • \$\begingroup\$ OK, you asked for the detail and the devil is in the detail. Maybe you need to raise a new question about the pros and cons of driving a particular motor you have in mind? \$\endgroup\$
    Feb 25, 2015 at 9:10
