7
In my project I want to use some ceramic and electrolytic capacitors, I will need the capacitors be at least 10V rated, but what will happen if I use much higher rated capacitors (just to make sure in case of something went bad they don't explode!)?
    \$\begingroup\$ Geesh, if I had known you were going to accept a answer in the first few minutes, I wouldn't have bothered to go into such detail \$\endgroup\$ Jun 20, 2011 at 17:23
  • \$\begingroup\$ possible duplicate of High Voltage Capacitor, in a low voltage system? \$\endgroup\$
    – Kellenjb
    Jun 20, 2011 at 19:52
  • \$\begingroup\$ @Olin - consolation: I always appreciate your extensive answers, very knowledgeable. Others do as well; in a short time you gained a lot of reputation. \$\endgroup\$
    – stevenvh
    Jun 21, 2011 at 7:32
  • \$\begingroup\$ @Olin Sorry I did not ment to be not thankfull, the answer I marked was enough at that time I wanted to order some caps, but now I really enjoyed your answer. Thanks. \$\endgroup\$
    – Dumbo
    Jun 25, 2011 at 11:11
    \$\begingroup\$ Even if you have enough information to make progress on your system, you should wait 24-48 hours to accept an answer. This gives more time for other users to post high quality answers. \$\endgroup\$ Jun 27, 2011 at 16:44
4 Answers 4
28
In general, the voltage rating of a capacitor is the maximum it can take and still stay within specs. Unpolarized caps, like ceramics, can take any voltage +- the voltage spec value. Polarized caps, like electrolytics and tantalum, can take any voltage from 0 to the voltage spec value.
That said, different things happen to different cap types as their voltage gets near the maximum. With electrolytics, the lifetime goes down. In theory with a reputable manufacturer, the rated lifetime is at max voltage and temperature unless stated otherwise. You could therefore say the lifetime goes up if you operate the cap below its rated max voltage. The two major stressers of electrolytic caps are voltage and temperature. Large currents can also hurt them, but this is due to heating so is really a temperature issue.
Ceramics have different properties. Voltage doesn't effect lifetime of SMD multilayer caps much, assuming of course you don't exceed specs. Some ceramics however do not linearly store charge as a function of applied E field. They hold less additional charge for the same voltage increment at high voltage than at low voltage. This means the apparent capacitance goes down with voltage. The cheap ceramics, particularly those with "Y" in their names and a few others exhibit this effect more strongly than others. If you are just bypassing a digital chip, this doesn't matter much. If however the cap is used in a analog filter, then this probably matters and you generally want to stick to ceramics with "X" in their name and look over the datasheet carefully.
There are issues with too low a voltage too, especially with electrolytics. They work on a thin oxide layer on the alumimum. This can get degraded when there is no charge accross it.
So to finally give you a concrete answer, if you are going to use electrolytic caps try to aim at running them around 3/4 or 2/3 of their rated voltage. It's OK to have occasional spikes up to the maximum, but don't ever exceed it. It's OK for them to be off too, but it's better that they're not completely discharged for years on end.
    \$\begingroup\$ Olin, Your effort in answering this quesiton so well is not wasted. I am an electrical engineer and have spent some years as an electronics designer. I enjoy reading your answers and bouncing it off of what I think I know. :-) \$\endgroup\$
    – Vintage
    Jun 20, 2011 at 20:38
You can always safely use caps rated at higher voltages. The only reasons not to are that they may be larger and more expensive.
See also answer to this question.
The value might be different from the marked value, if the operating voltage is much lower than the marked voltage, especially for electrolytic capacitors.
For ceramics, if 10V is your goal you will probably end up with 50V parts because that's a common voltage. I don't bother to have anything else on hand.
For electrolytics, 25V is a common voltage. Should be fine.
