For the following common-emitter amplifier, the original \$R_L = 4.7\space kΩ\$. When I replace it with a small value resistor (\$100\spaceΩ\$), the voltage gain will drop. Is there any way to drive the new low-impedance load without causing the degradation in the voltage gain?
Circuit Diagram
SetUp Details
\$ \space \space \space \space \space \space \space \space R_G=600\space Ω \\ \space \space \space \space \space \space \space \space R_1=82\space kΩ \\ \space \space \space \space \space \space \space \space R_2=15\space kΩ \\ \space \space \space \space \space \space \space \space R_C=4.7\space kΩ\\ \space \space \space \space \space \space \space \space R_E=910\space Ω \\ \space \space \space \space \space \space \space \space R_L=4.7\space kΩ \$
Thank you for your help.
