http://www.meanwell.com/search/LDH-45/LDH-45-spec.pdf
350mA = current.
Lets say my LED forward biases at 42v.
Is it a 120 ohm resistor that I need? 42V = 0.35A*120 Ohms
I am a bit confused. Typically when working with LEDs people call the resistor current limiting.
It will output whatever voltage between 18 and 86 volts that it needs to get 350 mA flowing in the LEDs. You don't need any resistor. This is the point of a constant current supply, you can put any load on it and know you will get the right current.
