I've been hunting high and low across the internet, but I haven't had any luck so far.
What I need:
Brass terminals/contacts that can be soldered on a PCB and will receive electrical plugs. I want it to be able to receive plugs of all standards. What I'm looking for are terminals like these, but PCB mounted:enter image description here
I can't find them anywhere, and I don't even know what to search for.
Edit:
I am looking for contacts that can be soldered onto PCBs, not complete housings. I need to produce a couple hundred of these PCBs, and the PCB must interface with the electrical plug directly.
  • \$\begingroup\$ Maybe electrodes. Your picture also shows a fuse holder. These can be bought PCB style. \$\endgroup\$ – Andy aka Feb 28 '15 at 10:19
  • \$\begingroup\$ There are quite a few around that can be soldered to PCBs, but in housings. Do you want the contacts only? \$\endgroup\$ – EM Fields Feb 28 '15 at 12:14
  • \$\begingroup\$ Yes, I want the contacts only. \$\endgroup\$ – arsalan86 Mar 1 '15 at 7:07
  • \$\begingroup\$ I've always called them "contacts", although some folks might call them "terminals". No doubt the manufacturers have terms for the internal features -- eg, the "fingers" that surround a pin might be called "wipers". \$\endgroup\$ – Hot Licks Mar 1 '15 at 13:47
  • \$\begingroup\$ Is there a reason you can't use an IEC inlet or outlet for this? C13/C14 is ubiquitous worldwide -- just ask for a "computer power cord". \$\endgroup\$ – ThreePhaseEel Sep 9 '16 at 23:36
AC plugs can be used with adapters. The adapters allow a UK style plug to fit in a US wall socket or a French wall socket and vice versa. You normally see them for sale at airports.
So, get yourself a bunch of adapters to suit the wall socket of your choice then buy a wall socket that is compatible with being soldered to a PCB. If it needs to be a regular wall socket on a flying lead then is this going to be a problem?
Maybe get one of these: -
From here
| improve this answer | |
