I am trying to create a logic circuit using only NAND Gates for this expression:
(NOT Q AND P) OR R
This question has really gotten me stuck! Can somebody please help?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI am trying to create a logic circuit using only NAND Gates for this expression:
(NOT Q AND P) OR R
The best way for a beginner is to think about each term separately and how you would create that with a NAND gate.
Let's start with the basic NAND gate truth table:
A | B | Q
0 | 0 | 1
1 | 0 | 1
0 | 1 | 1
1 | 1 | 0
Now let's look at each term. We have a NOT, and AND, and an OR in there. So, how can we make those with NAND gates? Start with the NOT.
How does a NAND look like a NOT? Simple - when both inputs are the same. If you tie A and B together so they always see the same signal, then you have a NOT gate. 0 nand 0 = 1, 1 nand 1 = 0. So the NOT gate can just be:
Next the AND. What's a NAND? It's an inverted AND. And AND with a NOT after it. So we just want to get rid of the NOT, and you can do that by adding another NOT:
Then comes the OR. Look closely at the NAND table and compare it to the OR table:
A | B | Q
0 | 0 | 0
1 | 0 | 1
0 | 1 | 1
1 | 1 | 1
Do you see a similarity? If you were to invert the A and B values the table would instead look like this:
A | B | Q
1 | 1 | 1
0 | 1 | 1
1 | 0 | 1
0 | 0 | 0
And that's the same sequence for Q as the NAND gate. So an OR gate is just a NAND gate with the inputs inverted. And we know how to invert already. So the OR looks like:
So now you know what the gates look like you can put the whole thing together:
However there's too many gates there. It can be simplified. The bit I have marked with a box - a NOT followed by a NOT - that's completely pointless (from a logic point of view) and is just wasteful. It serves no purpose. So you can get rid of it. Simplify to:
\$(\overline Q P) + R\$
\$=\overline{(\overline {\overline Q P}) \overline R}\$
= (NOT Q NAND P) NAND NOT R
