I would like to multiplex 8, 7-segment LED displays with two, 8-bit shift-registers. The required current for one segment is 20mA. I have no desire to overdrive the leds with 8 times the specified current, that will shorten their precious lifetime.
Since the displays are common cathode, the TPIC-6B-595 is suitable for sinking current, but I did not find any current-sourcing shift registers, so I need to use an octal buffer/line-driver. I prefer octal-buffers over Transistor/FET arrays.
The 74**541 and 74**244 datasheets are not clear about the current-sourcing parameters, to me it looks like they are only sinking and cannot handle 7+1 (dot) * ~30 mA = 240 mA.
This is the circuit diagram: Multiplexing 7 segment displays
Does anybody knows any solution to my problem?
  • \$\begingroup\$ I think you're calculating wrong. Each gate would only be sourcing the current for one segment, so only 20mA. \$\endgroup\$
    – Majenko
    Mar 1, 2015 at 21:19
  • \$\begingroup\$ Yes, but the whole device has to take 8*~30=240mA (worst case) which is far beyond any octal-buffer specs. \$\endgroup\$ Mar 1, 2015 at 21:22
  • \$\begingroup\$ Majenko is right. You are wrong. The whole device only has to produce 30 mA at any given instant. That said, 74**S is not a good way to source current. You "prefer octal-buffers over Transistor/FET arrays", but that just means you need a high-side driver. \$\endgroup\$ Mar 1, 2015 at 21:29
  • \$\begingroup\$ If all the 8 led, rated ~20mA each, (7 segment + 1 dot) is under power, how can the whole thing be only ~20-30 mA? \$\endgroup\$ Mar 1, 2015 at 21:34
    \$\begingroup\$ Ah you mean the whole device current - ok, yes that can be 240 max for your arrangement. \$\endgroup\$
    – Majenko
    Mar 1, 2015 at 21:36
In the "for what it's worth" category, this resource I found below lists quite a few latching constant-current LED drivers (8 and 16 bit). http://www.altera.com/literature/an/an286.pdf
Some of them actually have shift outputs so you can gang them together and write one long stream to the first device in the daisy chain.
