I am using MOSFETs in the ubiquitous RAMPS 1.4 Arduino shield for 3D printing use.
The MOSFETs switch the voltage to the heated bed and the hotend (where the filament comes out).
I need to replace one of the original MOSFETs, which is a STMicroelectronics STP55NF06L (datasheet). I chose to replace it with a TI CSD18532KCS (datasheet). Same TO-220 package, but I don't know if it will work properly.
So here are the specs for the STP55NF06L:
And here are the specs for the CSD18532KCS:
It appears that for most values, the two MOSFETs are very similar. But for RDS(on) (highlighted in red), the test characteristics are different, and the results are different. It's not a big difference (RDS(on) equals about 20 milliohms for the ST chip and about 4.5 milliohms for the TI chip).
I understand that RDS(on) is the resistance of the MOSFET when the gate-source voltage is at the sample VGS level. Because the difference between the two MOSFETS in RDS(on) is so minor, this shouldn't be an issue, right? The circuit isn't precise to more than 2 or 3 degrees of C for the heater cartridges anyway, so I believe it won't make a difference.
Are these MOSFETS interchangeable?
    \$\begingroup\$ The difference between 20 milliohms and 4.5 milliohms is more than a factor of 4. Don't dismiss it as "not a big difference". \$\endgroup\$ Commented Mar 2, 2015 at 14:39
8
The lower R_DS on in your proposed replacement will only help efficiency and won't cause any problems.
The output characteristic and transfer characteristic graphs are also worth comparing. The TI part appears to need a slightly higher gate drive voltage to get "turned on" to the same degree at the ST part. If the transistor were being driven with a marginal gate drive, that might be an issue, but from a quick look at the RAMPS schematic it appears the gate is being driven by a 5V output from the Arduino, which is enough to ensure that either of the transistors is fairly well saturated, so you should be good to go.
    \$\begingroup\$ It's also worth noting that the TI part has a lower gate charge, which also helps alleviate concerns about incompatible gate drive. \$\endgroup\$
    – W5VO
    Commented Mar 2, 2015 at 7:45
\$R_{ds(ON)}\$ would matter in case of huge currents (like 50A). Otherwise it should not matter in your case.
    \$\begingroup\$ The RAMPS board he's talking about is switching 10-15A, and the MOSFETs are often installed without heatsinks. It absolutely does matter -- especially since one has already burned out. \$\endgroup\$ Commented Oct 19, 2017 at 15:59
  • \$\begingroup\$ He did not mention any current at all. And he did not mention heat sinking either. \$\endgroup\$ Commented Oct 19, 2017 at 19:20
