How do you describe a boolean function using a K-Map in such a way that the boolean function depends on the previous value of this function?
    \$\begingroup\$ use previous output as one of the variable. \$\endgroup\$
    – nidhin
    Commented Mar 2, 2015 at 18:06
If the present output depends on previous output, then use the previous output as as one of the variable in truth table and K-map.
Take JK flipflop as an example:
J  K  Qn    Qn+1
0  0   0     0
0  0   1     1
0  1   0     0
0  1   1     0
1  0   0     1
1  0   1     1
1  1   0     1
1  1   1     0
