I have a red laser pen module: http://space-linker.com/Uploadfiles/UploadFile/2010178127739.jpg I want to be able to have it always on. How can I short the button, without having to glue or tape it down. Is there a circuit I can cut across with the power?
Button: https://cdn.sparkfun.com//assets/parts/9/0/00097-03-L.jpg
Thanks
  • \$\begingroup\$ Short the pins which are connected to the button with a piece of wire (solder a single wire to both of the button pins). \$\endgroup\$
    – Golaž
    Commented Mar 2, 2015 at 23:36
Yes, but...
You are removing the power switch and leaving yourself (and others) with no way to quickly disconnect power in the event of laser malfunction (fire) or immolation (laser setting something/someone in the room on fire).
Lasers can be dangerous!
Lasers can be dangerous, even small ones. Never point it someone's eyes. Treat them like a loaded gun -- always assume it is about to turn on and always point it in a safe direction. Remember reflections can also do damage, so avoid reflective surfaces and wear laser-grade eye protection.
That said... here's how:
Bypass the tactile switch by shorting across it's longest dimension as shown below. It doesn't matter which side (upper pair or lower pair from figures perspective) you use as the short sided legs are tied together internally in most parts.
    \$\begingroup\$ Thank you, worked it out before I saw this but its still the right answer! \$\endgroup\$
    – John
    Commented Mar 2, 2015 at 23:42
