In my upcoming project, I am working with a Microcontroller called the Microchip PIC32MX695F512H and a Wifi Module called the Microchip MRF24WB0MA. Since I am new to electrical engineering, I've pretty much just been copying what I learned out of the data sheets on their websites and an already made schematic utilizing these two parts (the links are below). There are pictures I put as well that are down below.
Although all seems to be going well, I am having a few difficulties. On pin 7 of the Wifi Module (RESET), each schematic seems to be connected to different wires with different resistor types. One is connected to +3.3V with a 4.7k resistor, and the other is connected to ground with a 100k resistor. One other thing is that although on one of the schematics, pins 33, 34, and 35 all have a 4.7k resistor, only pin 33 has a 4.7k resistor on the other schematics.
I'm really sorry if these are newby questions, but I just recently got in the field of electrical engineering and need an answer DESPERATELY! Thank you!
Links: Wifi Module Data Sheet: http://ww1.microchip.com/downloads/en/DeviceDoc/70632C.pdf Schematic that is already made: http://ww1.microchip.com/downloads/en/DeviceDoc/70678A.pdf
I think the first schematic is wrong. SPI is a push/pull, not an open drain bus. The datasheet specifically says pin 33 needs a pull-up, but not the others. \$\endgroup\$
