I have the task of building a sequence detector:
Here's the code :
/*This design models a sequence detector using Mealy FSM.
* Whenever the sequence 1101 occurs, output goes high.
* Overlapping sequences are allowed.
module firstFSM (
input wire clk,
input wire rst,
input wire sequence ,
output reg tick
//State declarations
localparam a = 2'b00 ;
localparam b = 2'b01 ;
localparam c = 2'b10 ;
localparam d = 2'b11 ;
//Signals
reg presentState ;
reg nextState ;
//State assignments
always @ (posedge clk , posedge rst )
begin
if(rst)     presentState <= a ;
else if (clk)   presentState <= nextState ;
end
//Next state logic
always @ *
begin
//Default or unassigned states remain same
nextState = presentState ;
tick = 1'b0 ;
case(presentState)
    a : if (sequence)   nextState = b ;
    b :
        begin
        if (sequence)   nextState = c ;
        else        nextState = a ;
        end
    c : if (~sequence)  nextState = d ;
    d :
        begin
        if(sequence)
            begin
            tick = 1'b1 ;
            nextState = b ;
            end
        end
    default :
            begin
            tick = 1'b0 ;
            nextState = a ;
            end
endcase
end
endmodule
Here's the testbench:
`timescale 1 ns / 1 ns
module firstFSMTest ;
//Signals
reg clk, rst ;
reg sequence ;
wire tick ;
//Initialise reg ports
initial
begin
clk = 1'b0 ;
sequence = 1'b0;
end
//Set initial reset
initial
begin
rst = 1'b1 ;
#30 rst = 1'b0 ;
end
//Set occurence of sequence
initial
begin
#30     sequence = 1'b1 ;
#20     sequence = 1'b0 ;
#20     sequence = 1'b1 ;
end
//Initialise uut
firstFSM uut (  .clk(clk),
    .rst(rst),
    .sequence(sequence),
    .tick(tick)
always #10 clk = ~clk ;
endmodule
Here's the output:
As you can see, the sequence 1101 does occur after the yellow line.
But, no matter what I do, the output doesn't go high. I am pretty sure the design and tb are correct. So where's the error?
  • \$\begingroup\$ Put the state variable in the output waveform. \$\endgroup\$ Mar 3, 2015 at 8:00
Your regs are defined wrong.
reg presentState ;
reg nextState ;
should be
reg [1:0] presentState ;
reg [1:0] nextState ;
By default, regs only have 1 bit so only states a and b can ever be reached.
Also, you should do your testbench a bit differently. Try
initial
begin
@(posedge clk);
@(posedge clk);     sequence <= 1'b1 ;
@(posedge clk);     sequence <= 1'b0 ;
$finish;
end
instead.
With those couple of changes, I am getting a pulse on the 'tick' output when I run this in Icarus Verilog.
