Can I use an SCR such as BT151 or BT136 (or even a triac such as TYN616), to pass a high voltage(400V) high frequency signal (pulsed DC at 50KHz) for a fixed period? such as 1 second on, then off for another second, then on again?
No. The off time is not enough for the thyristor to turn off AND the rate of rise of voltage (dv/dt) is going to be high enough to turn the thyristor on even without gate current.
Both factors are too high for general-purpose thyristors by at least an order of magnitude.
Use a MOSFET, a BJT or an IGBT. Or even a relay.
No SCR's latch on as long as there is a positive voltage difference across its anode and cathode
\$\begingroup\$ Hi. Thank you for the quick reply. But wont the pulsed DC reach below the Vth for the SCR, so if I shut off the control pulse, the next time the pulsed DC reaches zero, the SCR should shut off? \$\endgroup\$– dynamagMar 3, 2015 at 8:33
\$\begingroup\$ So it is the voltage source and the gate that is pulsed? SCR's are very slow at switching \$\endgroup\$– user16222Mar 3, 2015 at 11:07
\$\begingroup\$ The voltage source pulses at 50KHz. The gate at 1Hz. But, like Spehro Pefhany said, I need to use MOSFETs. Thank you for your input. \$\endgroup\$– dynamagMar 3, 2015 at 16:41
