I have a board with the ATSAM3S2BA-AU, which is a Cortex M3 uC. I need to use 2 PWM channel , here how I've done it :
 PIO_Configure(pPins, PIO_LISTSIZE(pPins));  //Pin mapping
/* Enable PWMC peripheral clock */
PMC_EnablePeripheral(ID_PWM);
PWMC_ConfigureClocks(EXCITATION_PWM_FREQUENCY * MAX_PWM_DUTY_CYCLE*2,
                     EXCITATION_PWM_FREQUENCY * MAX_PWM_DUTY_CYCLE,
                     BOARD_MCK);
/* Configure PWMC channel for 1  */
PWMC_ConfigureChannel( PWM,
               PWM_CHANNEL2,        /* channel */
                       PWM_CMR_CPRE_CKA,    /* prescaler */
                       0,                   /* alignment */
                       0);      /* polarity */
PWMC_SetPeriod(PWM, PWM_CHANNEL2, MAX_PWM_DUTY_CYCLE);
PWMC_SetDutyCycle(PWM, PWM_CHANNEL2, HALF_PWM_DUTY_CYCLE);
PWMC_EnableChannel(PWM, PWM_CHANNEL2);
/* Configure PWMC channel for 2  */
               PWM_CHANNEL0,        /* channel */
                       0,                   /* alignment */
                       PWM_CMR_CPOL);       /* polarity */
PWMC_SetPeriod(PWM, PWM_CHANNEL0, MAX_PWM_DUTY_CYCLE);
PWMC_SetDutyCycle(PWM, PWM_CHANNEL0, HALF_PWM_DUTY_CYCLE);
PWMC_EnableChannel(PWM, PWM_CHANNEL0);
this works fine, but when I change the order of the configuration, meaning setting channel0 first than the channel 2 , only the second still works, so the question is why ? I'Ve tried to figured it out reading the datasheet but it didn't help !
    \$\begingroup\$ Error is in code not shown. \$\endgroup\$ – Turbo J Jan 17 '17 at 14:54
