I am working with the nRF DK trying to read a sensor over I2C. I wrote some code in Keil uVision and I finally could read the sensor. However, for some weird reason I can't figure out, recently the twi_sw_master.c file gives some compilation errors.
compiling twi_sw_master.c...
RTE\nRF_Drivers\nRF51422_xxAB\twi_sw_master.c(136): error:  #254: type name is not allowed
          for (uint_fast8_t i=18; i--;)
RTE\nRF_Drivers\nRF51422_xxAB\twi_sw_master.c(136): error:  #65: expected a ";"
RTE\nRF_Drivers\nRF51422_xxAB\twi_sw_master.c(136): error:  #20: identifier "i" is undefined
RTE\nRF_Drivers\nRF51422_xxAB\twi_sw_master.c(311): error:  #254: type name is not allowed
      for (uint_fast8_t i = 0x80; i != 0; i>>=1)
RTE\nRF_Drivers\nRF51422_xxAB\twi_sw_master.c(311): error:  #65: expected a ";"
RTE\nRF_Drivers\nRF51422_xxAB\twi_sw_master.c(311): error:  #20: identifier "i" is undefined
RTE\nRF_Drivers\nRF51422_xxAB\twi_sw_master.c(384): error:  #254: type name is not allowed
RTE\nRF_Drivers\nRF51422_xxAB\twi_sw_master.c(384): error:  #65: expected a ";"
RTE\nRF_Drivers\nRF51422_xxAB\twi_sw_master.c(384): error:  #20: identifier "i" is undefined
RTE\nRF_Drivers\nRF51422_xxAB\twi_sw_master.c(474): warning:  #1-D: last line of file ends without a newline
  /*lint --flb "Leave library region" */
RTE\nRF_Drivers\nRF51422_xxAB\twi_sw_master.c: 1 warning, 9 errors
".\Objects\mag3110.axf" - 9 Error(s), 1 Warning(s).
Target not created.
Build Time Elapsed:  00:00:01
This is the library:
/* Copyright (c) 2009 Nordic Semiconductor. All Rights Reserved.
 * The information contained herein is property of Nordic Semiconductor ASA.
 * Terms and conditions of usage are described in detail in NORDIC
 * SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
 * Licensees are granted free, non-transferable use of the information. NO
 * WARRANTY of ANY KIND is provided. This heading must NOT be removed from
 * the file.
#include <stdbool.h>
#include <stdint.h>
#include "twi_master.h"
#include "nrf_delay.h"
#include "twi_master_config.h"
/*lint -e415 -e845 -save "Out of bounds access" */
#define TWI_SDA_STANDARD0_NODRIVE1() do { \
        NRF_GPIO->PIN_CNF[TWI_MASTER_CONFIG_DATA_PIN_NUMBER] = (GPIO_PIN_CNF_SENSE_Disabled << GPIO_PIN_CNF_SENSE_Pos) \
        |(GPIO_PIN_CNF_DRIVE_S0D1 << GPIO_PIN_CNF_DRIVE_Pos)    \
        |(GPIO_PIN_CNF_PULL_Pullup << GPIO_PIN_CNF_PULL_Pos)  \
        |(GPIO_PIN_CNF_INPUT_Connect << GPIO_PIN_CNF_INPUT_Pos) \
        |(GPIO_PIN_CNF_DIR_Input << GPIO_PIN_CNF_DIR_Pos);  \
} while (0) /*!< Configures SDA pin to Standard-0, No-drive 1 */
#define TWI_SCL_STANDARD0_NODRIVE1() do { \
        NRF_GPIO->PIN_CNF[TWI_MASTER_CONFIG_CLOCK_PIN_NUMBER] = (GPIO_PIN_CNF_SENSE_Disabled << GPIO_PIN_CNF_SENSE_Pos) \
} while (0) /*!< Configures SCL pin to Standard-0, No-drive 1 */
/*lint -restore */
#ifndef TWI_MASTER_TIMEOUT_COUNTER_LOAD_VALUE
#define TWI_MASTER_TIMEOUT_COUNTER_LOAD_VALUE (0UL) //!< Unit is number of empty loops. Timeout for SMBus devices is 35 ms. Set to zero to disable slave timeout altogether.
#endif
static bool twi_master_clear_bus(void);
static bool twi_master_issue_startcondition(void);
static bool twi_master_issue_stopcondition(void);
static bool twi_master_clock_byte(uint_fast8_t databyte);
static bool twi_master_clock_byte_in(uint8_t * databyte, bool ack);
static bool twi_master_wait_while_scl_low(void);
bool twi_master_init(void)
    // Configure both pins to output Standard 0, No-drive (open-drain) 1
    TWI_SDA_STANDARD0_NODRIVE1(); /*lint !e416 "Creation of out of bounds pointer" */
    TWI_SCL_STANDARD0_NODRIVE1(); /*lint !e416 "Creation of out of bounds pointer" */
    // Configure SCL as output
    TWI_SCL_HIGH();
    TWI_SCL_OUTPUT();
    // Configure SDA as output
    TWI_SDA_HIGH();
    TWI_SDA_OUTPUT();
    return twi_master_clear_bus();
bool twi_master_transfer(uint8_t address, uint8_t * data, uint8_t data_length, bool issue_stop_condition)
    bool transfer_succeeded = true;
    transfer_succeeded &= twi_master_issue_startcondition();
    transfer_succeeded &= twi_master_clock_byte(address);
    if (address & TWI_READ_BIT)
        /* Transfer direction is from Slave to Master */
        while (data_length-- && transfer_succeeded)
            // To indicate to slave that we've finished transferring last data byte
            // we need to NACK the last transfer.
            if (data_length == 0)
                transfer_succeeded &= twi_master_clock_byte_in(data, (bool)false);
            else
                transfer_succeeded &= twi_master_clock_byte_in(data, (bool)true);
            data++;
    else
        /* Transfer direction is from Master to Slave */
            transfer_succeeded &= twi_master_clock_byte(*data);
            data++;
    if (issue_stop_condition || !transfer_succeeded)
        transfer_succeeded &= twi_master_issue_stopcondition();
    return transfer_succeeded;
 * @brief Function for detecting stuck slaves and tries to clear the bus.
 * @return
 * @retval false Bus is stuck.
 * @retval true Bus is clear.
    bool bus_clear;
    TWI_SDA_HIGH();
    TWI_SCL_HIGH();
    TWI_DELAY();
    if (TWI_SDA_READ() == 1 && TWI_SCL_READ() == 1)
        bus_clear = true;
    else if (TWI_SCL_READ() == 1)
        bus_clear = false;
        // Clock max 18 pulses worst case scenario(9 for master to send the rest of command and 9 for slave to respond) to SCL line and wait for SDA come high
        for (uint_fast8_t i = 18; i--;)
            TWI_SCL_LOW();
            TWI_DELAY();
            TWI_SCL_HIGH();
            TWI_DELAY();
            if (TWI_SDA_READ() == 1)
                bus_clear = true;
                break;
    else
        bus_clear = false;
    return bus_clear;
 * @brief Function for issuing TWI START condition to the bus.
 * START condition is signaled by pulling SDA low while SCL is high. After this function SCL and SDA will be low.
 * @return
 * @retval false Timeout detected
 * @retval true Clocking succeeded
#if 0
    if (TWI_SCL_READ() == 1 && TWI_SDA_READ() == 1)
        // Pull SDA low
        TWI_SDA_LOW();
    else if (TWI_SCL_READ() == 1 && TWI_SDA_READ() == 0)
        // Issue Stop by pulling SDA high
        TWI_SDA_HIGH();
        TWI_DELAY();
        // Then Start by pulling SDA low
        TWI_SDA_LOW();
    else if (TWI_SCL_READ() == 0 && TWI_SDA_READ() == 0)
        // First pull SDA high
        TWI_SDA_HIGH();
        // Then SCL high
        if (!twi_master_wait_while_scl_low())
            return false;
        // Then SDA low
        TWI_SDA_LOW();
    else if (TWI_SCL_READ() == 0 && TWI_SDA_READ() == 1)
        // SCL high
            return false;
        // Then SDA low
        TWI_SDA_LOW();
    TWI_DELAY();
    TWI_SCL_LOW();
#endif
    // Make sure both SDA and SCL are high before pulling SDA low.
    TWI_SDA_HIGH();
    TWI_DELAY();
        return false;
    TWI_SDA_LOW();
    TWI_DELAY();
    // Other module function expect SCL to be low
    TWI_SCL_LOW();
    TWI_DELAY();
    return true;
 * @brief Function for issuing TWI STOP condition to the bus.
 * STOP condition is signaled by pulling SDA high while SCL is high. After this function SDA and SCL will be high.
 * @return
#if 0
        // Issue start, then issue stop
        // Pull SDA low to issue START
        TWI_SDA_LOW();
        TWI_DELAY();
        // Pull SDA high while SCL is high to issue STOP
        TWI_SDA_HIGH();
        TWI_SDA_HIGH();
            return false;
        TWI_SDA_HIGH();
        TWI_SDA_LOW();
        TWI_DELAY();
        // SCL high
            return false;
        TWI_SDA_HIGH();
    TWI_DELAY();
#endif
    TWI_SDA_LOW();
    TWI_DELAY();
        return false;
    TWI_SDA_HIGH();
    TWI_DELAY();
    return true;
 * @brief Function for clocking one data byte out and reads slave acknowledgment.
 * Can handle clock stretching.
 * After calling this function SCL is low and SDA low/high depending on the
 * value of LSB of the data byte.
 * SCL is expected to be output and low when entering this function.
 * @param databyte Data byte to clock out.
 * @return
 * @retval true Slave acknowledged byte.
 * @retval false Timeout or slave didn't acknowledge byte.
    /** @snippet [TWI SW master write] */
    // Make sure SDA is an output
    TWI_SDA_OUTPUT();
    // MSB first
    for (uint_fast8_t i = 0x80; i != 0; i >>= 1)
        TWI_SCL_LOW();
        TWI_DELAY();
        if (databyte & i)
            TWI_SDA_HIGH();
        else
            TWI_SDA_LOW();
            transfer_succeeded = false; // Timeout
            break;
    // Finish last data bit by pulling SCL low
    TWI_SCL_LOW();
    TWI_DELAY();
    // Configure TWI_SDA pin as input for receiving the ACK bit
    TWI_SDA_INPUT();
    // Give some time for the slave to load the ACK bit on the line
    TWI_DELAY();
    // Pull SCL high and wait a moment for SDA line to settle
    // Make sure slave is not stretching the clock
    transfer_succeeded &= twi_master_wait_while_scl_low();
    // Read ACK/NACK. NACK == 1, ACK == 0
    transfer_succeeded &= !(TWI_SDA_READ());
    // Finish ACK/NACK bit clock cycle and give slave a moment to release control
    // of the SDA line
    TWI_SCL_LOW();
    TWI_DELAY();
    // Configure TWI_SDA pin as output as other module functions expect that
    TWI_SDA_OUTPUT();
 * @brief Function for clocking one data byte in and sends ACK/NACK bit.
 * After calling this function, SCL is high and SDA low/high depending if ACK/NACK was sent.
 * @param ack If true, send ACK. Otherwise send NACK.
 * @return
 * @retval true Byte read succesfully
static bool twi_master_clock_byte_in(uint8_t *databyte, bool ack)
    uint_fast8_t byte_read          = 0;
    /** @snippet [TWI SW master read] */
    // Make sure SDA is an input
    TWI_SDA_INPUT();
    // SCL state is guaranteed to be high here
    // MSB first
            break;
        if (TWI_SDA_READ())
            byte_read |= i;
        else
            // No need to do anything
        TWI_SCL_LOW();
        TWI_DELAY();
    // Make sure SDA is an output before we exit the function
    TWI_SDA_OUTPUT();
    *databyte = (uint8_t)byte_read;
    // Send ACK bit
    // SDA high == NACK, SDA low == ACK
    if (ack)
        TWI_SDA_LOW();
    else
        TWI_SDA_HIGH();
    // Let SDA line settle for a moment
    TWI_DELAY();
    // Drive SCL high to start ACK/NACK bit transfer
    // Wait until SCL is high, or timeout occurs
    // Finish ACK/NACK bit clock cycle and give slave a moment to react
    TWI_SCL_LOW();
    TWI_DELAY();
 * @brief Function for pulling SCL high and waits until it is high or timeout occurs.
 * SCL is expected to be output before entering this function.
 * @note If TWI_MASTER_TIMEOUT_COUNTER_LOAD_VALUE is set to zero, timeout functionality is not compiled in.
 * @return
 * @retval true SCL is now high.
 * @retval false Timeout occurred and SCL is still low.
#if TWI_MASTER_TIMEOUT_COUNTER_LOAD_VALUE != 0
    uint32_t volatile timeout_counter = TWI_MASTER_TIMEOUT_COUNTER_LOAD_VALUE;
#endif
    // Pull SCL high just in case if something left it low
    TWI_SCL_HIGH();
    TWI_DELAY();
    while (TWI_SCL_READ() == 0)
        // If SCL is low, one of the slaves is busy and we must wait
        if (timeout_counter-- == 0)
            // If timeout_detected, return false
            return false;
#endif
    return true;
I am getting crazy with this. I already have my nRF51 DK reading the sensor, and now this same project just doesn't compile, neither does any other project I create with that library.
Can anyone help with this?
I even instaled again all the stuff in a different computer and it didn't work either.
Thank you.
[EDIT]
Also, it doesn't show a signal in the code pointing an error:
  • \$\begingroup\$ Does your compiler support inline variable declarations in for loops? As for gcc you need to set somthing like CFLAGS=-std=c99. Otherwise you possibly need to rewrite the for to something like int i; right after the function starts, and then for (i = 0; i < x; i++) \$\endgroup\$
    – Beryllium
    Commented Mar 3, 2015 at 17:57
  • \$\begingroup\$ Hello. I already tried that. If I write this: uint_fast8_t i; for (i=18; i--;){ Then I get a different error: "RTE\nRF_Drivers\nRF51422_xxAB\twi_sw_master.c(136): error: #268: declaration may not appear after executable statement in block" So it says I cant do that, doesn't it? I actually don't know why, though \$\endgroup\$
    – zapeitor
    Commented Mar 3, 2015 at 18:20
  • \$\begingroup\$ Well, that's what I meant by "right after the function starts". So try to move up uint_fast8_t i; - it must appear directly after bool bus_clear; \$\endgroup\$
    – Beryllium
    Commented Mar 3, 2015 at 18:56
  • \$\begingroup\$ Hello, I did that and in fact it works now. I actually was convinced it could not be a "sintaxis" problem since I assumed the library can't be wrong (and the fact that the same library compiled previously...) But actually re-writing it worked. Thank you. \$\endgroup\$
    – zapeitor
    Commented Mar 3, 2015 at 19:05
It seems that your C compiler does not support C99 out-of-the box.
  • So try to turn on C99. As for GCC, you have to add -std=c99 to the command line arguments. As for Keil try --c99. As an alternative, in Keil uVision, you can turn this on by clicking the "C99 Mode" checkbox in the "C/C++" tab in the project options (this has been pointed out by zapeitor in a comment).
  • Otherwise rewrite the code: In your case the declaration of the variable within the for statement is not valid. You have to move it up; it must appear right after the function's declaration:
void f() {
  int i;
  for (i = 0; i < 5; i++) {
instead of
void f() {
  for (int i = 0; i < 5; i++) {
The latter is only possible with C99.
  • \$\begingroup\$ Hi, like I said in my comment, you are right. But I am going to try this too and check if the original library works. Thank you. \$\endgroup\$
    – zapeitor
    Commented Mar 3, 2015 at 19:18
  • \$\begingroup\$ Hi. What you said can be done in Keil uVision by clicking the "C99 Mode" checkbox in the "C/C++" fan under project-options. Hi hope this can help someone else in the future. Thank you. \$\endgroup\$
    – zapeitor
    Commented Mar 4, 2015 at 14:16
  • \$\begingroup\$ You are welcome. I have added your comment in my answer; as I do not know uVision, is it a "fan" or a "tab" where this check box resides? \$\endgroup\$
    – Beryllium
    Commented Mar 4, 2015 at 14:42
  • \$\begingroup\$ Tab maybe? I am actually not sure (language problems), but when you click in options you see the "C/C++" thing. So whatever it's called they will find it. \$\endgroup\$
    – zapeitor
    Commented Mar 4, 2015 at 15:56
