Nidhin used multiplication, I'm going to use just the opposite (division) but it will really be just a bunch of subtractions, easy to do with an adder.
First, I'm going to assume all of the ASCII digits have been converted to BCD (binary coded decimal) by anding off the 0x30 (making each of the digits 4 bits instead of 8).
Let's take a couple of examples. Convert 26 (decimal) to 1A (hex)
0010 0110 => 0001 1010
The rightmost digit of our answer has a "weight" of 1, and the left digit a "weight" of 16. This because there are two four bit "nibbles" in the answer and the weight of the 5th bit is 16:
128 64 32 16 8 4 2 1
So we will be repeatedly subtracting 16 and use the number of successful subtractions as the left digit of the answer. What's left becomes the right digit.
If we subtract 16 from 26, we get ten. Since we can only do this once (without it going negative), the left digit becomes 1 and the right digit is A (10).
26
-16 -> 1 (since we did this once)
10 -> A so the answer is 1A or 0001 1010
(done because 10 < 16)
A longer example:
Convert 92 (decimal) to 5C (hex).
1001 0010 => 0101 1100
92
-16
76
-16
60
-16
44
-16
28
-16 -> 5 (since we subtracted 5 times, this is where the counter would be useful)
12 -> C so the answer is 5C or 0101 1100
(done because 12 < 16)
Note that although I am showing decimal arithmetic (e.g. 92 - 16) this is really being done in BCD -- a 4-bit nibble for each ASCII digit.
So subtracting 16 from 92 actually needs to done using a BCD adder. It's not as complicated as it seems, here's an example:
1001 0010 92
- 0001 0110 16
1000 1100 80 + -4 because it's negative, we'll add 10 back and propagate the carry
0001 1010
0111 0110 76, which is the correct answer (see above)
